Go Back   Honda-Tech > Honda and Acura Technical Forums > Hybrid/Engine swaps
Old 10-02-2012, 11:51 AM   #1
CtotheODY
Default H22 swap wiring harness
Ok so i have a pretty simple question, since im doing an h22 swap into an ek civic, if i buy the prelude engine harness, would that eliminate the need for any cutting, splicing etc? It should just be hook up and go right? Also would this bypass some of the electrical issues like bogging under acceleration, rough idling and cel's?
Thank you
Cody
CtotheODY is offline   Reply With Quote
Old 10-02-2012, 12:12 PM   #2
boostedb18ls
Default Re: H22 swap wiring harness
The Prelude wiring harness will not plug into your Civic chassis, as they have different style plugs that connect where the factory shock tower plugs meet up. If you're using stock harnesses you will need to do a bit of splicing and wiring yourself, or if you aren't comfortable with wiring there are always options like Chase Bays. I had one of their harnesses on my H22 DC2 and I didn't have any issues.
-Spencer
boostedb18ls is offline   Reply With Quote
Old 10-02-2012, 12:20 PM   #3
h22crxpwr
h22crxpwr's Avatar
Thank you
Cody
no you can't use it. you will use your existing harness and just add and extend wires. Or you can buy one already made. I make my own harnesses for these swaps.
Good luck,
h22crxpwr is offline   Reply With Quote
Old 10-02-2012, 01:06 PM   #4
CtotheODY
Damn so even if i use the prelude ecu i have to splice still?
Old 10-02-2012, 01:08 PM   #5
h22 civic
h22 civic's Avatar
Send a message via AIM to h22 civic
yup i have both harnesses un cut if interested
h22 civic is offline   Reply With Quote
Old 10-02-2012, 03:54 PM   #6
CtotheODY
I checked out that chase bay and i would love to get that if it wasnt $550... Are there any other harnesses that dont cost nearly that much?
And i may be interested depending on the price
Old 10-02-2012, 04:40 PM   #7
h22crxpwr
h22crxpwr's Avatar
Dont use the prelude ecu. its garbage. use a p28. easier, less sensors to wire.
I make harnesses if you are interested PM me. for a lot less than $550!! especially if you send me your harness first that will save you a LOT of money. Pm me if you are interested.
Old 10-02-2012, 07:39 PM   #8
CtotheODY
I sent you a PM
Old 10-03-2012, 10:31 PM   #9
the171
1991 Honda Civic
the171's Avatar
As stated, you already have the harness if you have the one that came with the car. The idea is to plug it in where possible, extending wires and whatnot, and then plugging it in to your chassis. Some plugs get removed, and some need to be added depending on what accessories you choose to run, and what ecu you're using. Using Hondata or whatever lets you customize things.
It sounds real complicated, but it isnt. Take your harness, and lay it over the engine. Go from there.
H23 EG. Toyota T100. Kicking it old skool.
the171 is offline   Reply With Quote
Old 10-04-2012, 11:56 AM   #10
CtotheODY
Well i think i have decided to use the stock harness but now im wanting to find someone to either make a connecting harness or do the wiring for me
Old 01-16-2013, 08:13 PM   #11
HighHPHatch
2000 Honda Civic
HighHPHatch's Avatar
I just bought the cm1 harness from Chase bays for a H22 euro r in to a 00 Civic hatch, they left me with 3 wires I had to splice in to the factory ecu plugs? Which makes no sence to me... Can anyone help?
HighHPHatch is offline   Reply With Quote
Old 01-17-2013, 04:17 PM   #12
turboHondaWesJ
turboHondaWesJ's Avatar
iTrader Rating: (2)
Likely wires for the knock sensor, vtec solenoid, and vtec pressure switch. What color are the wires? Trace them back to their respective plugs/post a pic.
turboHondaWesJ is offline   Reply With Quote
Old 01-21-2013, 09:52 PM   #13
HighHPHatch
2000 Honda Civic
The two wires are for my fuel pump and CEL Green/red is fuel pump splice into your factory fuel pump wire on your A plug, Orange/Blue is your check engine light do the same thing with it, + a brown wire to ground and check the cel codes. The problem is I can't find the "A" plug on the harness.. chassis or engine! It's just not there! I wish I had pics to show..
Old 01-22-2013, 09:58 PM   #14
HighHPHatch
2000 Honda Civic
Bump for any input
Similar Threads
what would i need for a H swap! crxbape Hybrid/Engine swaps 6 06-16-2014 06:00 PM
92-96 prelude wiring harness h22 b18cvtec Honda Prelude 7 07-23-2013 06:56 PM
H22 Wiring Harness for swap CodyCRX Honda CRX / EF Civic (1988-1991) 1 03-17-2013 09:18 PM
OBD2 H22 Harness in OBD1 Chassis KillinEm18 Tech/Misc 0 12-04-2012 10:45 AM
h22 Owners - long block + Transmission Sensors/ plugs List ? rhd91integra Hybrid/Engine swaps 2 11-05-2012 05:08 PM
