Honda Insight & CR-Z Hybrid Honda Insight and CR-Z Hybrid discussion forum.
is this correct
Old 10-02-2012, 02:25 AM
MACH 7's Avatar
Default is this correct
its from wikipedia
B20B/B20Z
1999 - 2001 specs
NON-VTEC Found in: USDM CRV as a B20Z, CR-V and Honda Orthia as a B20B Displacement: 1,973 cc (120.4 cu in)
Power: 250 hp (186 kW) @ 7800 rpm
Torque: 195 lb·ft (264 N·m) @ 6800 rpm
Rod length: 137 mm (5.4 in)
Compression: 9.6:1
Bore: 84 mm (3.3 in)
Stroke: 89 mm (3.5 in)
Redline: 8500 rpm
and does this come automatic
Old 10-02-2012, 03:02 PM
MACH 7's Avatar
Default Re: is this correct
hard one i guess
Old 10-03-2012, 04:05 PM
MACH 7's Avatar
lonely here
Old 10-03-2012, 04:45 PM
TunerN00b's Avatar
1) You should link the page you pulled that from.
2) Why was this posted in the Insight/CR-Z Forum?
Old 10-03-2012, 05:20 PM
MACH 7's Avatar
http://en.wikipedia.org/wiki/Honda_b_engine#B20B
heres the link
i did post this in the wrong place ma bad hopefully a admin will move it
Old 10-04-2012, 10:44 PM
MACH 7's Avatar
verify plz
Old 10-31-2012, 08:01 AM
truckman's Avatar
yep
ReillyEK
03-11-2013 04:58 PM
Sorcereryk
07-18-2007 10:49 AM
joey funk
06-19-2007 02:52 PM
duyfash0
21
06-16-2007 01:12 PM
Sorcereryk
01-06-2005 03:00 PM
Quick Reply: is this correct
