Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 09-19-2012, 01:25 PM   #1
wasp9166
Default icu replace?
my intermittent wipers will work when turned on ,then they pretty much do what they want, work sometimes other times i have to wait
through a search i read it's due to bad capacitors on the icu which is under the fuse panel?
is this part no longer available from honda?
or anyone else?
91 civic dx
wasp9166 is offline   Reply With Quote
Old 09-19-2012, 02:49 PM   #2
91STDFLOW
91STDFLOW's Avatar
Default Re: icu replace?
ICU controls the Inter. Wipers. Big grey gameboy looking box on the back of your under dash fuse panel, should have a big A or B depending on which one. Junkyard is where i always get them from or you can call Honda and ask.
Love your 88-91 EF'n Honda? Check out the Maniacs at
www.facebook.com/EFManiacs <--
90-91 CIVIC HB/CRX FS Thread <--
91STDFLOW is offline   Reply With Quote
Old 09-20-2012, 02:00 PM   #3
wasp9166
this is called the mcu, multifunction control unit is it not?
i'm pretty sure the ignition control unit is in the diz?
Old 09-20-2012, 02:05 PM   #4
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
It's called the ICU for 4th generation Civics.
You could also have a bad switch, which can be cleaned.
Don't guess, troubleshoot.
