b16a swap in eg - no spark
Old 09-08-2012, 05:35 PM
streethondar's Avatar
Default b16a swap in eg - no spark
I have a jdm b16a swap in my eg. It has been convetered form OBD0 to OBD1. I have changed the injectors, dizzy, and wirining harness. I am using a SOHC D-series harness on the b16a. Now here is the issue "NO SPARK". I have a P28 ECU.
I have checked wiring, coil, igniter, grounds (thermostat, valve cover, transmisson). I am using a GS-R Dizzy housing with D15b7 dizzy guts. New gs-r cap and i have a new d15b7 ignition rotor.. I see no spark marks inside the cap at all. I am getting power to my dizzy.
What could be my issue?
streethondar is offline
Old 09-08-2012, 07:32 PM
Former User's Avatar
Default Re: b16a swap in eg - no spark
Does voltage reach the coil and igniter unit?
Does the fuel pump prime?
Do the injectors pulse fuel?
Former User is offline
Old 09-08-2012, 07:34 PM
i used a test light on where the 2 screws go onto the coil and they both have power, yes fuel pump does prime and yes i do have fuel.
Old 09-08-2012, 07:37 PM
A P28 ECU is not a match for your engine.
Also click the spark link in my signature. Test the coil and igniter unit. Do the igniter unit input tests detailed in a diagram in the FAQs sticky.
Old 09-08-2012, 07:42 PM
done did all these test and all test out to be fine and a P28 ecu is the ecu u use to run a b16a swap in a eg.
Old 09-08-2012, 07:44 PM
Stock or chipped ECU?
You may also have the wrong distributor.
Stock P28, but that wont matter. I just wont be able to rev above 7k rpm.
Old 09-08-2012, 07:46 PM
You have the wrong ECU and possibly the wrong distributor.
Have you also tested the Yel/Grn wire for a short or open?
Does the cam turn when you crank the engine?
Old 09-08-2012, 07:48 PM
i have no idea why i come on here and ask for help.. a stock p28 runs a b16a just fine.. i have done this many times.. was just very stumped on the dizzy thing.. i will order a new dizzy and try that and it should fix it..
Old 09-08-2012, 07:50 PM
yes, wiring on the WHOLE CAR IS FINE!! car is in time.
Good question.
Old 09-08-2012, 07:53 PM
Good question
well if your gona be a wise guy, at least know what the heck your talking about.. every time you have ever gave me input on anything it has not been the issue. I have found every single issue myself.
Old 09-08-2012, 07:54 PM
You are clearly unreceptive to help and you are also a wise guy. /thread
Ueichi
07-28-2012 05:38 PM
efinfroman
18
08-29-2010 11:10 AM
GSR_EJ2
16
09-03-2009 07:02 AM
jeremiah963
09-02-2008 11:29 AM
Andy R
07-25-2005 09:21 PM
Quick Reply: b16a swap in eg - no spark
