94 accord vtec solenoid
hey guys my 94 accord is leaking oil from the vtec solenoid & i wanted to replace the gaskets, wondering if anyone knew what to remove in order to get the vtec solenoid out, thanks
Re: 94 accord vtec solenoid
You should be fine by just removing the three bolts on the assembly. I will warn you that it's a pretty tight fit because of the intake manifold.
