manual transmission fill plug (s)?
Old 08-18-2012, 08:49 AM
91 Wagon's Avatar
Default manual transmission fill plug (s)?
Hi, I have a 91 accord wagon. I'm looking to change my trans fluid, but I'm not sure which plug to fill from? I have read the faq and searched, but my trans seems different.
Here are some pics. Drain?:
Fill?:
All three are square holes, no sign of a hex head.
Also, I have a couple bottles of redline MT90 in the garage, I haven't heard much about using this, I understand the Honda MTF is good, but I have no other use for the MT90... What do you think about using this fluid?
Old 08-18-2012, 02:31 PM
djkurious's Avatar
Default Re: manual transmission fill plug (s)?
You have the fill and drain bolts correct. I personally use Honda MTF, but over on Acurazine, the folks there swear on the Redline fluid for their auto trannys.
Old 08-18-2012, 06:47 PM
91 Wagon's Avatar
Which is the fill? My hand is pointing at two
Old 08-18-2012, 07:55 PM
djkurious's Avatar
IICR, Fill is at the top, second pic where your 1st finger is pointing. Drain is at the bottom.
Old 08-18-2012, 10:57 PM
holmesnmanny's Avatar
In the second pic, the fill plug is the bottom one. Obviously, the drain plug is the one at the far bottom.
Old 08-19-2012, 08:30 AM
Lost Again's Avatar
Just me here but the fill plug is actually seen in the first pic....
You can just see it, rear of the CV shaft.
Old 08-20-2012, 02:51 AM
91 Wagon's Avatar
Oh, so what am I pointing at in the second pic?
Old 08-20-2012, 03:13 PM
Lost Again's Avatar
Sealing bolts....#34 and #35 in this pic......not the fill hole for the trans.
The upper sealing bolt "seems" close to the true fill bolt but is higher IMO, so if you don't want to follow the proper procedure and us it.....good luck. Overfill your trans - it is your car. I'd use what the factory wants you to use.
EDIT: Which is #41 in the pic and the same as posted before. again, your car......do as you please.
dth0ng69
10
07-20-2012 06:07 AM
blouthan
Transmission & Drivetrain
03-06-2009 05:01 PM
SpazMan
04-29-2008 09:41 AM
mark_is_gay
04-14-2006 04:49 PM
Adam_F123
11-25-2005 11:05 AM
Quick Reply: manual transmission fill plug (s)?
