Old 07-30-2012, 05:50 PM   #1
hawjboiz08
Post 92 integra starting problems
hi
i have a 92 integra gsr that im having trouble with. couple weeks ago i was driving then all of a sudden it just stalled out on me. i have changed the distributor on it that day and it started up just fine but then right when i drove it bouts a mile or two it died again so i towed it back to the house. since then i've been trying to crank it up but nothing...the fuel pump was working fine but then as of now i cant hear it priming at all...i just replaced the mfr today and it started right up again but as soon as i took it down the road it died again..not sure whats the problem. when u turn the key to on it's silent and sometimes i would hear something like a short circut kind of noise from the mfr...help me please if u can cause im getting tired of buying parts for the car thats not neccassary
hawjboiz08 is offline   Reply With Quote
Old 07-30-2012, 06:11 PM   #2
sirtef9
sirtef9's Avatar
iTrader Rating: (4)
http://www.facebook.com/vtedpowa
Default Re: 92 integra starting problems
main relay, replace that, its unnder the driver side of the dash. Brown square deal. Known issue for hondas/acuras of that year. It controls the pgmfi
1992 Gs-R #1143, 7/12/13, 375whp 14lbs, stock b17, e-85
1999 Subaru Legacy Outback, daily driver
1991 Honda Civic Si, under construction
sirtef9 is offline   Reply With Quote
Old 07-31-2012, 06:55 AM   #3
hawjboiz08
just did yesterday and it started up just fine but as soon as i drove it the car died again...now fuel pump is not priming...i have a new fuel pump on the way but imma also test the fuel pump thats in the car too...im not getting any fuel, i even opened the fuel filter and no spray when trying to crank the car...any ideas besides fuel pump?
Old 08-01-2012, 12:47 AM   #4
Solster
1991 Acura Integra
Solster's Avatar
might be a defective Main relay
it's rare but it happens take it back and complain till they exchange it
91 Integra B18C1 GS-R Swap
Originally Posted by b20forlife View Post
Ok so I figured it out. I guess my alternator was actually 180 out so that's fixed.
Solster is offline   Reply With Quote
Old 08-01-2012, 05:55 AM   #5
fcm
Old Fart
fcm's Avatar
Simple enough to test...
Test the yellow/white lead at the PGM-FI Main Relay plug for power, from fuse 38-10A, [hot at all times] in engine bay fuse box.
If there is power on the yellow/white...
Unplug the PGM-FI Main Relay and use a jumper to connect the yellow/white with the yellow/black, there are two (2) yellow/blacks, one is fuel pump power the other is fuel injector power, one of them will turn on the fuel pump, the other will supply power to the fuel injectors, either way, if the fuel pump does not turn on, jumping to either one, the pump is bad.
If the pump does work, check the ground, [black] for the PGM-FI Main Relay and for switched power to the PGM-FI Main Relay, black/yellow, fuse 24-15A, [hot in run and start] in under dash fuse box and the blue/white, fuse 18-7.5A. [hot when cranking to start only] in under dash fuse box. 94
RIP Zack 2001-2013, my best friend.
fcm is offline   Reply With Quote
