Go Back   Honda-Tech > Community Forums > General Discussion and Debate
Old 07-27-2012, 02:22 PM   #1
NSXRguy
NSXRguy's Avatar
Send a message via AIM to NSXRguy
Default Question about Seafoam engine treatment
Ive used seafoam on all my cars so i know all about how to actually "suck" it into the engine.
My question is how much is too much?
I have a supercharger on my c32b and used one of the vacuum lines on te side towards the firewall. Fed about 1/2 the can into it. I thought it was a bit weird that only one my muffler outlets was smoking. Didnt mind it much because during winter time, only that side would smoke also. It did the whole smoking of the highway thing.
Today, i was bored so i sprayed seafoam blaster in the vacuum ports and cleaned out my tb as well as i could. This time, i used a dofferent vacuum line, which would be more center on the supercharger. The car immediately started smoking white, but this time both exhaust outlets smoked. I can even say i polluted the environment more this time than last. Cars actually stayed behind me more. I also have test pipes.
So now the question. If you seafoam a very clean engine with very little carbon buildup, will it still smoke? Is the smoke due to the seafoam mostly? Or carbon mostly?
And how frequent is too frequent? I want to seafoam it until i have no smoke, but i dont want to ruin the motor and possibly ruin my rings or walls. Thanks!!
1997 Acura NSX-T - Spa Yellow / Ebony
2007 Acura TL Type S - Alabaster Silver Metallic / Taupe / Ebony
NSXRguy is offline   Reply With Quote
Old 07-27-2012, 02:26 PM   #2
Evs-One
Solbros Owns Me
Evs-One's Avatar
Send a message via ICQ to Evs-One Send a message via AIM to Evs-One
Default Re: Question about Seafoam engine treatment
Seafoam will leave you with a lot of smoke, even when the deposits are cleared.
Some others, like Amsoil Power Foam, will stop smoking once the carbon build ups are cleared.
Evs-One is offline   Reply With Quote
Old 07-27-2012, 02:28 PM   #3
__oversea
__oversea's Avatar
seafoam will bring every fire departments in your city.
__oversea is offline   Reply With Quote
Old 07-27-2012, 02:29 PM   #4
hapexamendios 2.0
R.I.P.
2002 Lamborghini Gallardo
hapexamendios 2.0's Avatar
In my experience it smokes less the "cleaner" the engine is..
“Life is like a movie, if you've sat through more than half of it and it’s sucked every second so far... No one should blame you for walking out early.”
hapexamendios 2.0 is offline   Reply With Quote
Old 07-27-2012, 02:29 PM   #5
bigdent
bigdent's Avatar
Send a message via AIM to bigdent
I heard every 10-20k miles for the de carb interval
bigdent is offline   Reply With Quote
Old 07-27-2012, 02:30 PM   #6
rota92
I give out free hugs
2004 Honda S2000
My Garage
rota92's Avatar
Send a message via AIM to rota92
I find it works best if you remove the spark plugs and flush out the carbon in the cylinders with it. Definitely smokes on startup but it goes away when the motor stops running.
rota92 is offline   Reply With Quote
Old 07-27-2012, 02:32 PM   #7
Builda'Teg_92
Builda'Teg_92's Avatar
boy is seafoam fun lol
BoOsted Stock b20 Build....http://honda-tech.com/showthread.php?t=3065370
Originally Posted by slayer423 View Post
trust man, all the people that I know with reliable built turbo Hondas honestly slang a lot of kush...
Builda'Teg_92 is offline   Reply With Quote
Old 07-27-2012, 02:36 PM   #8
Evs-One
Solbros Owns Me
Evs-One's Avatar
I've actually gained 20-30 psi compression in an engine by removing the plugs and allowing sea foam to soak in overnight on top of the piston/rings.
Old 07-27-2012, 02:38 PM   #9
skateboard_ej8
skateboard_ej8's Avatar
iTrader Rating: (4)
Ahh, i could never get myself to do this sea foam thing to any engine.
Stock D16ZC 264hp/248ftlb 13.23 psi E85
skateboard_ej8 is offline   Reply With Quote
Old 07-27-2012, 02:41 PM   #10
rota92
2004 Honda S2000
My Garage
rota92's Avatar
Did you crank it with the stuff on it to act like a wet test? That'll increase it all by itself.
I do not trust putting **** like that anywhere near a motor lol
Old 07-27-2012, 02:45 PM   #11
98civdx
Master Detailer
98civdx's Avatar
This. I almost did but I was too
98civdx is offline   Reply With Quote
Old 07-27-2012, 03:13 PM   #12
MonkeyMagic
MonkeyMagic's Avatar
Send a message via AIM to MonkeyMagic
+1
reminds me of that "stop smoke" ****.. like, hey *******, if you need something like that, you just need a new engine.
...and don't go 20,000 miles between oil changes this time.
MonkeyMagic is offline   Reply With Quote
Old 07-27-2012, 03:15 PM   #13
kidcool1977
SHAME ON YOU REBECCA!
kidcool1977's Avatar
Is it true doing it to often will kill the engine?.
sent from my laptop in the comfort of my house.
kidcool1977 is offline   Reply With Quote
Old 07-27-2012, 03:51 PM   #14
solbrothers
y u rusty doe?
1970 Honda CB450
My Garage
solbrothers's Avatar
iTrader Rating: (1)
solbrothers
Send a message via AIM to solbrothers
lets talk about this. i want to do it to teggy but fear it will make it worse
Originally Posted by 94EG8 View Post
Some guys get tattoos together, some guys go to the gym together, then there's Ash and Solbrothers: Lifetime alignments together
Originally Posted by Rguy View Post
I actually laughed. Well done sol.
solbrothers is online now   Reply With Quote
Old 07-27-2012, 04:02 PM   #15
Knightsport
You're a daisy if ya do
2009 Ford F-250
My Garage
Knightsport's Avatar
Knightsport
Might remove all your rusts.
I'm your Huckleberry.
http://honda-tech.com/forumdisplay.php?f=11
Knightsport is offline   Reply With Quote
Old 07-27-2012, 04:04 PM   #16
solbrothers
y u rusty doe?
1970 Honda CB450
My Garage
iTrader Rating: (1)
solbrothers
:fckthat:
Old 07-27-2012, 04:05 PM   #17
ritalin.v2
ritalin.v2's Avatar
Father time 80
Send a message via AIM to ritalin.v2
My engines must be remotely clean. Hardly see any smoke at all.
'91 NA CW
ritalin.v2 is offline   Reply With Quote
Old 07-27-2012, 04:14 PM   #18
NSXRguy
NSXRguy's Avatar
I just seafoamed my dads 90k mile camry... Smoked like crazy which is good. Probably fed about 1/2 the can into it.
My dad wants to do it again hoping to get rid of more of the carbon. This is why i want to know if the smoke is due to the seafoam or more th carbon buildup
Old 07-27-2012, 04:29 PM   #19
slomofo
GDD Member
1991 Geo Metro Type-R
slomofo's Avatar
iTrader Rating: (1)
solbrothers xtrac1 George Knighton ILcrxsi1 uncle_ben markspan6243
Send a message via ICQ to slomofo Send a message via AIM to slomofo Send a message via MSN to slomofo Send a message via Yahoo to slomofo Send a message via Skype™ to slomofo
Sea foam is petroleum based, do you think the smoke is caused by anything other than the seafoam? The smoke you see is almost entirely sea foam.
Originally Posted by turbohatch96y7 View Post
I love a good creampie!
slomofo is offline   Reply With Quote
Old 07-27-2012, 04:34 PM   #20
rota92
2004 Honda S2000
My Garage
rota92's Avatar
Drive it harder and burn that **** up the proper way lol
Old 07-27-2012, 04:36 PM   #21
90_EX_Civic
1991 Honda Civic
My Garage
90_EX_Civic's Avatar
inb4xtrac
90_EX_Civic is offline   Reply With Quote
Old 07-27-2012, 04:36 PM   #22
A.C. Slater
A.C. Slater's Avatar
Jgtc15
1000 times this, especially in an NSX out of all cars
wood try in an old pos ford escort
inb4 ppl saying
I PUT SEAFOMEZ IN MY b16 AND GAINED 6WHP
Albert Squad FTW!
Spoon lip scrapin, spoon n1 screamin, spoon mirrors reflectin, spoon sw388's rollin, spoon wing downforcin spoon stickers stickin
A.C. Slater is offline   Reply With Quote
Old 07-27-2012, 04:45 PM   #23
solbrothers
y u rusty doe?
1970 Honda CB450
My Garage
iTrader Rating: (1)
solbrothers
inb4 ppl saying
does not commute
Old 07-27-2012, 04:49 PM   #24
.Manny.
Touching My Member
1990 Honda Civic
.Manny.'s Avatar
Why get rid of that sweet compression raising carbon?? Lose horsepowers. no thx
Originally Posted by doctorake View Post
This thread is worse than sucking ten dicks at once.
.Manny. is offline   Reply With Quote
