Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda Prelude
Old 07-21-2012, 05:58 AM   #1
niterider96cord
Default Power steering leak!?
Problem is im leaking power steering fluid horribly. I have looked and looked and looked to figure out where it might be coming from but I keep coming back to the same location \/ What i dont understand is why it would be leaking power steering fluid from the transmission. Am i missing something?
I am about to just say screw it and yank it all out and say forget power steering but i figured id see what you guys had to say first.
Sorry for the bad pic, very difficult to get under neath the prelude.
niterider96cord is offline   Reply With Quote
Old 07-21-2012, 06:40 AM   #2
mafia
mafia's Avatar
Default Re: Power steering leak!?
Best way to find the leak IMO, is buy some degreaser Spray your bay, pressure wash it. Then you'll be able to track it much easier.
00-PY ITR 420whp
96-hx 42mpg
mafia is offline   Reply With Quote
Old 07-21-2012, 06:43 AM   #3
minilogoguy18
West way to look at leaks, from the bottom, do like said, clean the bay and look from the top before looking underneath.
93 BB2 - JDM H22a/T2W4 Euro R transmission
Originally Posted by PirateMcFred View Post
Everyone's ****'s broken and they can't find a Helm Manual to read.
minilogoguy18 is offline   Reply With Quote
Old 07-21-2012, 11:48 PM   #4
niterider96cord
alright so cleaned the engine with degreaser and pressure wash both top and bottom. Waited until it was mostly dry and took a look. top side everything was dry not even left over water, no leak. bottoms side, jacked the car up and took a better picture of what im looking at and can cofirm this is indeed where the leak is coming from.
How is this happening!!!? I do not understand, powersteering is the only fluid that is disappearing, all other fluids stay the same.
Old 07-22-2012, 02:43 AM   #5
1funryd
1funryd's Avatar
Does your VSS have the two hoses going into it? This would be a 4th gen VSS. If so, that is where you powersteering fluid comes from.
The VSS uses the powersteering fluid. I have it on my H23 swapped 3rd gen Prelude.
One or both of those small powersteering hoses are leaking due to age and or a crack somewhere on them. Just replace them and you are good.
Here are pics:
Project Manager for the new Aftermarket for the 3rd gen Prelude(88-91) www.1funryd.com
Email: 1funryd@comcast.net
Ksport & Cometic Dealer.
1funryd is offline   Reply With Quote
Old 07-22-2012, 11:10 AM   #6
carnot
carnot's Avatar
X2, likely leaking from lines going to/from VSS.
carnot is offline   Reply With Quote
Old 07-22-2012, 06:46 PM   #7
minilogoguy18
Well you do seem to have a diff seal leak, pretty easy fix, might wanna do something about it before you destroy fifth gear in your car from low fluid.
Make a pin ***** in the inner tie rod boots, if the seals at the rack ends are leaking it'll fill those boots and you may not see it right away.
Old 07-22-2012, 08:52 PM   #8
niterider96cord
How do I fix the seal leak? I have a Chiltons manual but the driveshaft removal seems to be a pain in the ***. Is there a "easy" way?
Also can you elaborate a little more on the second part of your post? The seals on rack show no sign of leaking and dont look to be in bad condition either.
Old 07-22-2012, 09:01 PM   #9
niterider96cord
Both hoses good condition no leaking/cracking whatsoever.
Old 07-23-2012, 03:13 AM   #10
minilogoguy18
Chilton manuals suck, get the one published by Honda, the Helms.
I meant the rubber boots on the power steering rack ends, poke a tiny hole in each one, when the rack end seals leak you wont see any fluid right away because it'll fill those up like water balloons.
Old 07-23-2012, 10:19 AM   #11
5SpdH22
something gnarly
1969 Lexus IS
5SpdH22's Avatar
get a flywheel cover too
5SpdH22 is offline   Reply With Quote
Old 07-23-2012, 05:49 PM   #12
InvaderTrax
InvaderTrax's Avatar
Send a message via AIM to InvaderTrax
And replace that missing bolt
Originally Posted by v8h8 View Post
Cool build! I cant really tell what is what from the pictures. I also like the fact that you have a KNN air filter, those are a must!!! Just swap for a V-TECH head and youll be set!
InvaderTrax is offline   Reply With Quote
Old 07-26-2012, 04:24 AM   #13
niterider96cord
Alright besides my missing misc. items. What am I needing to replace to stop the leaking, that is my primary concern right now.
Also to minilogoguy18 I will ***** the boots this weekend, what will this tell me pertaining to the leak? Say they are filled with liquid, or not.
Old 07-26-2012, 04:47 AM   #14
carnot
carnot's Avatar
If you ***** the boots covering the rack ends and fluid leaks out this means that the actual rack itself is leaking and you will likely need to get a remand rack.
The fluid leak at the transmission where the intermediate shaft enters is independent of your power steering fluid leak. You need to address both fluid leaks. I would trace the power steering lines going to/from the VSS to see if there is a leak somewhere else that is causing power steering fluid to leak down and drip from the transmission housing.
fluid, leak, power, steering, transmission
