FTW, c16, q16, e85, let's talk fuel
Old 07-16-2012, 06:48 PM
  #26
Tuner Eddy's Avatar
Default Re: FTW, c16, q16, e85, let's talk fuel
Originally Posted by utahturbosohc
c16 will be more than enough for your goal. My fuel system is the same (with the exception of the injectors, I have bosch 1000's) and motor/setup is almost identical. We easily made it past 600hp on c16. and would be easier on the pocket book vs other fuels on your list. Minus e85. like they said, fuel system would be an issue there. And I've always been afraid of consistency with pump ethanol. Our local pump is never the same.
Thanks man. Good to see another single cam guy. How many pounds of boost are you running and what size turbo?
Old 07-16-2012, 07:00 PM
  #27
utahturbosohc's Avatar
PTE 6262. 618hp@32psi. Had no timing in it. But on the pull before that, it cracked the block, we didnt catch it until this pull. so we stopped there.
Old 07-16-2012, 07:11 PM
  #28
miller's Avatar
then it had to much timing in it if it cracked the block.
Old 07-16-2012, 07:22 PM
  #29
13*peak ve. Looks like cyl pressure trying to lift the head, but started pulling the block apart. It cracked the front from the coolant drain plug on the front of the block up to a head stud. Same thing happened to speedfactory. thats when James built that crazy brace. I just drilled each end of the crack, ground it out a bit and welded it. Never had an issue after that.
Old 07-16-2012, 07:30 PM
  #30
Tuner Eddy's Avatar
Do you know if they sell that brace or was it a one-off for his car?
Old 07-16-2012, 07:35 PM
  #31
It was a one off as far as I know. But I would suggest pulling the drain plug from the front of the block, and weld in an aluminum plug. It solved the problem. Both my self and SF did that one after we cracked em. neither have had any problems since.
Old 07-17-2012, 05:49 AM
  #32
ScorpioMk's Avatar
anyone tried the shell urt gas yet? I have seen threads on other boards but havent noticed one on honda-tech.
Old 07-17-2012, 03:31 PM
  #33
prj
prj's Avatar
anyone have experience with vp112? i can get it locally for $9/gallon.
Old 07-17-2012, 03:42 PM
  #34
tony1's Avatar
We use URT on our race gas GTR builds, it's good stuff.
Old 07-17-2012, 04:15 PM
  #35
JohnWigger's Avatar
I keep hearing about this FTW stuff but short of it having Nitro in it I can't see how it would make any more power than the E99 I run right now. I would be more than willing to try it if it was readily available.
Old 07-17-2012, 04:26 PM
  #36
13173's Avatar
First I have really heard of this Shell URT. Is this something they will put at select stations or do you have to special order this?
Also, which one works best 100, 105, or the Advanced?
Old 07-17-2012, 05:05 PM
  #37
SonicRacing1's Avatar
Hopefully they don't close this like did the other fuel thread smh... good info on this fuels im gonna have try FTW fuel sounds promising
Old 07-17-2012, 05:07 PM
  #38
spectacle's Avatar
Google is your friend.
Old 07-17-2012, 06:07 PM
  #39
Garage_Boy's Avatar
If 500-550 is your goal, E85 will work. I have a D2B as well, Mine is 505whp/349trq @25psi on a 5857SP .63ar. Stock sleeve w/ wiseco/eagle, bisi 3.6 cam, stock port head. As for your set e.t, it will come down to driver experiences. I ran my best pb of 10.52@135 with 457whp.
Old 07-17-2012, 06:21 PM
  #40
Enzo-Racing's Avatar
nevermind
Old 07-17-2012, 08:51 PM
  #41
13173's Avatar
I googled it, that is how I found out about the different choices of the Shell URT, I did not see a listing of stations participating in the URT sales.
Since this is a discussion about fuel, my question was geared towards fuel, and something I am unfamiliar with, I feel I can ask on a message board for an answer.
Old 07-19-2012, 07:13 AM
  #42
vtekthis's Avatar
Originally Posted by Enzo-Racing
nevermind
^^^ with this guy
Old 07-19-2012, 07:26 AM
  #43
dturbocivic's Avatar
ill be the third wheel haha
Old 07-19-2012, 07:15 PM
  #44
fukenboostin's Avatar
Anyone have any experience with pro racing fuels?
http://www.proracingfuels.com/products/pro-racing-fuel/
Old 07-19-2012, 11:19 PM
  #45
FarmYard's Avatar
im with utahturbosohc c16 will be enough for mid 10's. c16 d16 50 trim 10.4 for me with 480 whp.
Old 07-19-2012, 11:47 PM
  #46
extralargenog's Avatar
URT is awesome. YTou dont need anything more than that or C.
Old 07-21-2012, 08:09 PM
  #47
V-SPEC 1's Avatar
How much is the URT cost? From 100 to advanced?
Old 07-22-2012, 03:46 AM
  #48
tepid1's Avatar
Approx $50 for 5 gallons
Old 07-22-2012, 04:12 AM
  #49
fourthchirpin's Avatar
has anybody thought of Shell URT? .......... just adding fuel to the fire. unleaded that is. lol
Old 07-22-2012, 08:33 PM
  #50
ScorpioMk's Avatar
How does it compare to c16? Cost compared to c16 as well as power.
Quick Reply: FTW, c16, q16, e85, let's talk fuel
