1991 Honda Civic EF Hatchback Dx
Bought for $1,500 (7-10-12)
Engine: D15B2 SOHC 1.5L
Transmission: Manuel 5 Speed
Title: Clean
Mile's: 285k
Front:
Rear:
Engine Bay:
Interior Front:
Interior Rear:
Trunk:
Title: Clean
Mile's: 285k
Front:
Rear:
Engine Bay:
Interior Front:
Interior Rear:
Trunk:
To Do List (Maintenance)
02 Sensor
Oil Change
Intake Filter
Spark Plug's And Wire's
Distributor Cap And Rotor
Box Of Fuse's
Lucas Injector Cleaner
Oil Change
Intake Filter
Box Of Fuse's
Re: 1991 Honda Civic EF Hatchback Dx
i saw the 15w40 box and said to myself oh no! then i was the text lol.
welcome to the little blue hatch club.
clean little car for that kind of mileage
I knew the box would throw people off. Waiting for final part's to come in and then ill be posting the pic's.
So your the person that beat me to this, i was in the process of trying to buy.....damn good buy. Back to the hunt for me. Good luck..
Problem's Fixed
Noticed the timing belt was so loose that if i wouldnt stepped on it on the way home the engine wouldnt blew. Lucky for me i got it home and tightened it.
Valve Cover Removed
Timing Belt Cover and Alternator Pulley Removed
Also while doing this ive noticed that they changed the timing belt but they left the damaged alternator belt, so i got a new one.
Master Pro Alternator Belt $13.04
Valve Cover Removed
@SOLO1racer: So you the one that called to look at it when i was on my way there.
@m.e.s.a and M-Benz: That's the first thing i wanted to change.
Time For The Box. . .
The Box Of Good's
K&N Intake Filter 39.99
NGK Spark Plug Wire's 54.36
NGK Spark Plug's 9.96
Distributor Cap 19.99 (Lifetime Warranty)
Distributor Rotor 7.99 (Lifetime Warranty)
Box Of Fuse's 15.99
Lucas Injector Cleaner 6.29
Bosch O2 Sensor 36.99
Total: $191.56
Box Of Fuse's 15.99
Total: $191.56
Also got the oil change done which ended up being $30.90. Was worth it cause i got to use there lift to check how thing's looked on the bottom.
Re: Reason For The Fuse's
Looks 100% accurate. Someone replaced your tailight fuse with a 30A because that is all they had probably. Also, you're only missing a radio fuse - don't feel like you need to fill up all the slots! LOL!
Except for the sunnroof (Si), Radio is gone so thatll stay out for now. Will put the correct fuse into the taillight. Extra fuse's aint bad to have.
Installed Part's
K&N Intake Filter
NGK Spark Plug's and Wire's, Distributor Cap and Rotor
Exhaust Vibration Problem
When i drive at high rpm's the exhaust starts vibrating so i checked exaust and found no Gasket in between exhaust and converter so i got one.
Exhaust Pipe Gasket $3.99
1989 Honda Civic Si USDM Restoration
