Best size turbo for daily gsr
Old 06-23-2012, 08:52 AM
scott757's Avatar
Default Best size turbo for daily gsr
Im lookin to boost my gsr swapped ej1 . Fully built , skunk2 intake manifold , and I was wondering what is the best size turbo for this setup , I was told 57/58 but just looking for some input . It is my daily driver as well .
Old 06-23-2012, 08:58 AM
The Grumpiest
grumblemarc's Avatar
Default Re: Best size turbo for daily gsr
This question cannot be answered with the lack of information in your post.
Old 06-23-2012, 09:31 AM
Red-Rocket's Avatar
what's your power goal?
what's your budget?
what shape is your engine in?
do you know where your closest tuner is?
just a few of the questions you need to ask yourself before you go forced induction
Old 06-23-2012, 01:06 PM
Red-Rocket's Avatar
OP I would click on the link in grumblemarc's signature, How to Turbocharge your civic he comes off as an ******* but he REALLY knows his stuff
Old 06-23-2012, 01:49 PM
The Grumpiest
That link won't help him if he doesn't have a budget, goal, and a plan.
Old 06-25-2012, 05:57 AM
scott757's Avatar
My bad , I'm looking for 300 to the wheels , fully built engine , pistons , rods , cams ,
Old 06-25-2012, 05:58 AM
scott757's Avatar
Budget is 1,000 and I know a couple people who can tune
Old 06-25-2012, 06:05 AM
SovXietday's Avatar
Originally Posted by scott757
My bad , I'm looking for 300 to the wheels , fully built engine , pistons , rods , cams,
:facepalm:
Nope.
Old 06-25-2012, 06:21 AM
Bix VT's Avatar
Expect it to cost around $3,000 for a decent setup. You could probably do it for $1,500 if you used a lot of junkyard parts, but most OEM turbos won't work well on a GSR because the turbine is designed to spool fast, not have top-end breathing. A 14b or Volvo T3 .42/.48 won't get you to 300whp.
http://www.go-autoworks-store.com/gocotuki.html
Check out the Tuner kit. Keep in mind that you will still need some sort of EMS, bigger injectors, and for 300whp you'll also want a fuel pump and performance clutch.
Rule of thumb for turbo setups is to pick two of the following options: Fast. Reliable. Cheap. You can have two, but not all three.
Old 06-25-2012, 07:01 AM
4genaccordfreak's Avatar
I think the OP was saying budget for a turbo is $1000.
Not for the whole kit.
OP might want to confirm.
Old 06-25-2012, 07:25 AM
TKERacer619's Avatar
garrett gt2860rs. I just took one off my gsr. Fkn blast on the street man.
Lots of fast spooling. Hard to beat stoplight to stoplight if you can get traction down low. The tq comes in fast. If you're shooting for 300 this turbo will get you there and get you there fast. I was able to lay down 353 with it.
What manifold and downpipe setup do you have?
Old 06-25-2012, 07:54 AM
FlewByU352's Avatar
Disco potato is perfect! You can get the GT series for $600-800 new as everything is being replaced by the Garrett GTX series. If you had a higher budget I'd say the GTX3076R as it would spool about as fast as the GT2860RS but have much higher headroom for an easy 400WHP.
Old 06-25-2012, 08:33 AM
Moderator
TheShodan's Avatar
Actually, prices on average are still in the $1100-$1150 range. The GTX will be supplementing the GT-R series, not replacing it.
This guys needs to be specific yes.. listing camshafts, power levels etc. Many different journal and ball-bearing options are available. But he needs to give information, so that we don't go into a frenzy of "let's guess the right turbo"..
Old 06-25-2012, 08:53 AM
FlewByU352's Avatar
Whoever is paying that much is an idiot. Enjuku had them for like $670 shipped brand new in the boxes!
Old 06-25-2012, 09:51 AM
Moderator
TheShodan's Avatar
Ken at Enjuki had this sale for the GT2860R (GT28R) not the Disco Potato. That uses a different compressor package.
He had these until they ran out earlier in the year (about April). They were only internal gated .64A/R setups only. They are back to normal prices as listed...Sorry.
If he has it again, may be worth looking into.
Old 06-26-2012, 03:33 AM
scott757's Avatar
yes yes , 1000 is the budget for the turbo only .. I have an ACT stage 3 clutch and skunk2 short throw shifter, not really stressin money right now , already putting somewhere in the area of 200 hp to the wheels .. but my block and head are fully built, skunk2 valves , retainers, got hondata s300 v2 otw ,walboro 255 lp-h fuel pump otw , as well as rc 370cc injectors , mizu radiator, hasports mounts and axles , just lookin for turbos. Also, I need this setup to be reliable as possible
Old 06-26-2012, 03:57 AM
spectacle's Avatar
Need bigger injectors
Old 06-26-2012, 07:00 AM
scott757's Avatar
What cc
Old 06-26-2012, 07:49 AM
Cole D's Avatar
Injector dynamics 750 or 1000cc
Old 06-26-2012, 07:51 AM
LightningTeg's Avatar
For 300whp?
Old 06-26-2012, 07:56 AM
phaphon's Avatar
theres a injector calculator somewhere. and you still have not mention what pistons/rod set up you have and whats the compression?
Old 06-26-2012, 09:01 AM
Yes. I would run 750cc
Old 06-26-2012, 10:47 AM
AlexDphoto's Avatar
No reason why you couldnt run 1,000s and have a low duty cycle while giving yourself more room to grow in the future. Everyone gets bitten by the boost bug, might as well be prepared. Plus, if it were ID1000's or RC/Precision 750's id run the ID's all day.
Old 06-26-2012, 11:45 AM
Kaze-Speed's Avatar
You'll be good with a journal bearing 57mm turbo honestly for daily driving. You don't want a turbo spooling too early or else you'll kill a lot of fuel.
Old 06-26-2012, 02:13 PM
th3pwn3r's Avatar
I think it has a lot more to do with driving style than anything when it comes to fuel consumption but I've been wrong before.
Quick Reply: Best size turbo for daily gsr
