How much is K20 swap total cost? B or K series
#26
Re: ???? How much is K20 swap total cost ???? B or K series ?????
do a k20 reliable power..yea yea b20 vtec or ls vtec..which ive owned both and idc what anyone says there not going to be as reliable as a slightly modded oem k20..all internals stay the same..no sandwich kits..no piecing a motor together..
again u guys keep talkin boost..lets stick with motor for motor..k20 bigger displacement higher reving...and the cfm's it flows..lol..trumps the b16/b18..
dont get me wrong honda builds/engineers great engines..i still think the b16/b18c's..are still ahead of its time..light free reving..pretty low maintenece.ther than burning oil..lol
and if anyone is local tojersey i have a base k20 out of a 06 rsx..complete block for $300 with papers..also an rbc and a couple k20 harneses for cheap..let me kno..
#27
1 Post
Yeah no boost for me. My boost days were over when i switched from nissan 240's to honda's. I believe hands down when it comes to a reliable 250 n/a build k20 is the way to go.
#29
for the b18c i just spent 5000 total on a new motor, transmission, ecu, godspeed turbo kit, install and tune. and installed that into me 93 integra and im pushing 300+ whp
#30
what tune neptune crome..or is it hondata
not to take anything away from your build..300hp is nothing to scoff at
and you got a "brand new" as in zero miles..never ever been used?
and like someone said above..you could find a k24 accord motor cheap..like 500 at most..trust me ive done a few..and i belive the most expensive part of the build was all the gas you will end up consuming driving around
#31
I put over 6k in my used parts and K20z3 swap..... Make a list and dont splurge on stuff u dont need like bling bling stuff. My k20 swap was better than any B motor i ever driven...All in all if u think about it , modding a car is a never ending money pit. Regardless if its a D,B,F,H or K..... I changed cars and motor every year until i went K-swap.
#33
i did a hondata i belive and brand new as in i bought it from a jdm used motor dealer it had around 30-40 k and the only reason i went god speed was because i am planning on getting my frends set up after he does his k swap.
#34
1 Post
I prob will go with the K swap honestly. I just love the thought of a Very mild built K20z1 or z3 in my teggy with 250. Its going to be a pain to do this but hey NO PAIN NO GAIN right. Keep me posted on this so i know how much to count for the swap I want to buy it all at once.
#35
250 is possible out of a 20 but it's not exactly mild. the k20 type r is roughly a 200whp engine. you're going 50 up over that.
#37
1 Post
I was thinking k20z1 with intake/header/exhaust, intake mani, head port and polish, mild cams, kpro hondata tune.
#39
#40
Looking at all these number makes my head hurt. Good luck either route. If you're going N/A I say go K!
All this money being talked about is why I live the D's. 800 bucks+ shipping for a D15b with lsd trans.
#42
that's my point. poster says a k20 at 250whp. you then cross it to a k24 which can get to 250whp fairly easy. a k20z1 with a couple bolt ons isn't gaining 50-60whp
#44
where's the dyno the engine started at? since all dynos can read differently, gains over stock would be much more showing than a hp chart. is that flywheel corrected? is it really cold out? if the engine really gained 50-60hp with just those mods i would be shocked as ****
#45
been there done that
cant find a before sheet but here's one against another k20 with similar bolt on's and stock cams. sae corrected of course.
i have similar bolt on's and these same cams but not yet installed. i'll make sure to do some before runs for comparison on my setup.
#46
1 Post
I am taking my thread back. I decided to go with a mild built K20/K24 setup. I did get some unnecessary parts due to future valvetrain plans. I have everything needed to put the swap together minus simple stuff like coil pack, T/B sensors, pulleys, and trans cables. If you have these Hook me up PM me. I cant tell you how much it cost because while buying all this I also bought suspension stuff, A daily driver, and clothes, got a new place (what can I say I came back from a deployment this is what we do). So what do you think my numbers will be. And what do you think about my build. This is what I have and am in the process of installing amoung other things.
HEAD:K20A
Beehive valve springs
Ferrea Flat Valves
A/C and P/S Delete
ID 1000cc Injectors
SKUNK2 pro series Manifold
Battle Grounds header
07 Z3 Civic SI cams
74mm Throttle Body
C.A.I.
and the Hybrid Racing Tuck Fuel Kit
BLOCK:K24A
Bored .050 over
CP 13:7 Pistons
Type S oil pump(sprung)
3in Exhaust with wide open dumps at the push of a button
the compression will be close to 14:1
Race fuel prob 113
Walbro 255 of course
HEAD:K20A
Ferrea Flat Valves
A/C and P/S Delete
ID 1000cc Injectors
07 Z3 Civic SI cams
74mm Throttle Body
C.A.I.
BLOCK:K24A
Bored .050 over
CP 13:7 Pistons
Race fuel prob 113
#48
Also remember that with newer motors, the manufacturers name of the game is for efficiency , not power. You can get an lsvtec turbo setup for less than a k series and blow the doors off most k series swapped Hondas anyways
#49
Depends if ur luck and abundance in your area. I know k-series are aboundant. But id go with b series. I bought a gsr for $1k. Beause the old lady didnt know what she was selling lol.
