Honda Fit Honda Fit (Jazz)
Old 03-25-2015, 10:58 AM
How-Tos on this Topic
Last edit by: IB Advertising
Print Wikipost
how do i reset the airbag light?? help please
Old 06-21-2012, 08:06 PM
luis_ej8's Avatar
Default how do i reset the airbag light?? help please
Does any one know how to reset the airbag light I tried to look it up with no luck ...any help is much appreciated thanks!
Old 06-22-2012, 01:22 AM
claymore's Avatar
Default Re: how do i reset the airbag light?? help please
1. turn ignition switch off, remove ECU service connector
2. connect (jump) the MES connector (this is 2 pin yellow connector wrapped in yellow plugged in the front of the underdash fuse box)
3. turn ignition switch on
4. SRS light will come on for 6 secs then go out, remove the jumper within 4 secs after the light goes out.
5. the SRS light will come on again, reconnect the jumper within 4 secs after the light has come on.
6. the SRS light will go off, remove the jumper with in 4 secs after the light has gone off.
7. the SRS light will blink two times indicating the memory is reset.
Link to finding MES connector. It's not a Fit but will give you a general idea
http://www.hondapitstop.com/accord/t...1/SRS/srs.html
Old 06-22-2012, 11:17 AM
Tracyd's Avatar
try trhis:
Ignition Key Method:
1) Turn IGNITION on (but don't start car)
2) After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.
3) Wait 4 seconds
4) Turn IGNITION on (but don't start car)
5) After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.
6) Wait 4 seconds
7) Turn IGNITION on (but don't start car)
8) After the AIR BAG warning lamp lights for 7 seconds, turn IGNITION off within 1 second.
9) Wait 4 seconds
10) Turn IGNITION on (but don't start car)
11) Wait 3 seconds
12) Turn IGNITION off
13) Wait 2 seconds
14) START Car (the light may be blinking slower than before)
15) Wait 3 seconds
16) Turn IGNITION off
17) Wait 3 seconds
18) START Car
HOPE THIS HELPS!!!
Old 07-06-2012, 05:56 AM
kingteg's Avatar
What year is your fit?
Old 07-06-2012, 09:10 AM
luis_ej8's Avatar
2010
i tried both methods and they didnt work
Old 07-16-2012, 06:05 AM
FitsMe's Avatar
This is a dumb question, but maybe something is wrong with your airbag system?
Old 07-16-2012, 09:07 PM
claymore's Avatar
YEP ^^^^^^^^
Old 09-21-2012, 11:44 PM
technicaldan's Avatar
I've seen a few come through recently with second left side impact sensor internal circuit failure faults, a quick bit of trim removal, a few wire wiggles and a quick session on the hds seems to sort it. . . . Of all the srs faults i've seen recently, this seems to be the most common on both home builds and imports. . . . Might be worth a quick wiggle ?
Old 03-08-2017, 01:39 PM
RadioRF's Avatar
What is the ECU service connector?
Old 01-08-2024, 11:12 AM
JAM79IE's Avatar
Originally Posted by Tracyd
try trhis:
3) Wait 4 seconds
6) Wait 4 seconds
9) Wait 4 seconds
11) Wait 3 seconds
13) Wait 2 seconds
15) Wait 3 seconds
17) Wait 3 seconds
18) START Car
HOPE THIS HELPS!!!
Thanks!
undrh2o
10
12-19-2009 11:42 AM
rmk9785e
09-30-2007 09:49 AM
fastfu
11-14-2005 04:31 AM
DumpedSi
09-11-2003 08:42 PM
Mrivera21
05-28-2003 03:03 PM
Quick Reply: how do i reset the airbag light?? help please
