Starter issue
Old 06-05-2012, 05:10 PM
viciousvisionslarry's Avatar
Default Starter issue
hi guys i bought a 95 ls with a bad motor. I swapped in a b18b out of a 97 integra everything is cool with the swap now the starter is acking up. It was just replaced now its clicking. Itll start is i keep messing with the key but it clicks the first couple times i turn the key. The starter was perfect before the motor swap.
Old 06-05-2012, 05:13 PM
integra_101's Avatar
Default Re: Starter issue
check the ground wire that runs from the starter to the front clip
Old 06-07-2012, 12:02 AM
Ok I don't have a ground wire on the starter where would I be looking for the wire to come from or go to?
Old 06-07-2012, 06:10 AM
fcm
Old Fart
fcm's Avatar
There is no ground at the starter, the starter grounds through it's case.
Your problem may be a grounding issue, to check, leave door open so dome light stays on, watch dome light as you try and start the car, if the dome light goes out when you hear the "click", you have a grounding problem, redo your main grounds, batt. cable clamp and post, batt. to chassis ground and chassis to engine ground.
If dome light does not go out it is not a grounding problem and is most likely the high current contacts in the starter motor solenoid... https://honda-tech.com/forums/showth...+starter+motor 94
Old 06-07-2012, 07:53 AM
my 01 integra has a ground wire going from the starter to the front clip. aswell as my 1990 integra
Old 06-07-2012, 10:50 AM
fcm
Old Fart
fcm's Avatar
Never seen a ground lead/cable on and Integra starter, and all the wiring diagrams I have looked at do not show one.
Some thing added maybe, post a pic of them.
Not even sure why it would need one as the starter grounds through it's case to the engine, [transaxle] 94
Old 06-07-2012, 10:54 AM
sorry, it doesnt run to the front clip. it runs to where the air intake is. that platform.
Old 06-07-2012, 11:28 AM
fcm
Old Fart
fcm's Avatar
Pic please. 94
Old 06-07-2012, 11:45 AM
kyden's Avatar
there is no ground wire on the starter.
Old 06-07-2012, 12:09 PM
i cant find one. but ill take a pic of mine. its a brown wire.
People have issues with this because they put the wrong starter in their car and the ground wire burns and melts.
Old 06-07-2012, 12:24 PM
kyden's Avatar
again, no.
hondachris1994
12
11-09-2017 05:15 PM
crxjatt
16
07-16-2013 03:08 PM
Shaw14
03-06-2011 04:58 PM
twentyhurtz
12-14-2009 12:28 PM
candyman206
02-09-2006 10:09 PM
Quick Reply: Starter issue
