2003 CRV A/C Compressor Clutch will not engage, troubleshooting
Old 06-05-2012, 04:48 PM
sonnyny's Avatar
Default 2003 CRV A/C Compressor Clutch will not engage, troubleshooting
Hi-
Bought this 03' CRV 105K 5spd in March. I turn the A/C switch on and the fans do run but the compressor clutch does not engage. I checked the line pressure which was too high so I evacuated some refigerant until my guage read within specs. The refigerant has not leaked since. Compressor wires are connected. Switched the relay under the hood with a known working relay. I know there is a pressure switch but don't know where it is located (on condensor?)
Can anybody tell me what the step by step troubleshooting procedures are? Thanks!
Old 06-05-2012, 09:11 PM
NZ-DB8R's Avatar
Default Re: 2003 CRV A/C Compressor Clutch will not engage, troubleshooting
Put 12v DC onto the clutch yourself and see if it engages, if it does you know its a wiring fault/supply fault. If it doesnt then you know its the clutch coil
Old 06-06-2012, 02:09 AM
wes wagon's Avatar
Originally Posted by sonnyny
Hi-
It's on the passenger side hard line, after the condenser.
Old 06-10-2012, 06:32 AM
soon2bdropped's Avatar
replacd the clutch and coil, i do about a dozen a month.
Old 06-10-2012, 10:07 AM
fitseries3's Avatar
jump the pressure switch and see if it kicks on. if so, your pressure is too low. did you check the pressure while the car was running? it will read WAY different once the car is running IF the compressor engages.
rockycat
08-26-2014 05:35 PM
whahappened
Acura TSX
11-02-2012 03:20 PM
accord99power
08-18-2012 12:30 PM
19integra91
06-12-2008 06:02 PM
Accordn95
06-25-2007 04:25 PM
Quick Reply: 2003 CRV A/C Compressor Clutch will not engage, troubleshooting
