97 Accord EX 2.2 A/C compressor clutch won't engage
Old 06-02-2012, 09:33 AM
jvcordero's Avatar
Default 97 Accord EX 2.2 A/C compressor clutch won't engage
Hi.
Here is the problem I’m having:
My 1997 Honda Accord EX 2.2 A/C stopped working. The Compressor clutch won't engage.
First checked system has pressure on both high and low sides, installed a relay from a friend car to discard a relay failure. Also jumped A/C pressure switch (this caused the fans to turn on and the idle to raise). Those tests not engage the compressor clutch.
I pulled out the A/C relay, on A/C relay plug, with switch on, have 12v on BLK/YEL and WHT cable. If I jumped the BLK/YEL and RED cable and the cutch engage. Check the RED/BLU cable has no power and no ground. Another think, if I grounded the RED/BLU and connect the relay to the A/C plug, the clutch engages.
When the A/C switch on the dash is on the condenser fan is running.
Any ideas? Please help me find an answer.
Old 06-03-2012, 10:46 AM
Lost Again's Avatar
Default Re: 97 Accord EX 2.2 A/C compressor clutch won't engage
You are not getting the "ground" to the realy from the ECM via the red/blu wire.
What were the pressure readings from the high and low side....and under what conditions.
Old 06-03-2012, 02:25 PM
jvcordero's Avatar
Can't check the system high pressure because adapter is broken. On the low pressure has 35 psi with the car off. With the car on and RED/BLU grounded has 45 psi.
Old 06-04-2012, 04:07 PM
poorman212's Avatar
Then this is not true?
Any work done to the car recently?
Willing to test the pins at the ECU? A15 should be the ground from the ECU.
Old 06-05-2012, 03:29 PM
jvcordero's Avatar
I will continue with the troublesooting on Saturday. Really need back my air conditioner. It's verry verry hot in Puerto Rico.
Old 06-05-2012, 04:53 PM
poorman212's Avatar
Understand that....in order to help we really need to know the situation......hence the questions
Old 05-02-2013, 04:22 PM
joshiebdapimp's Avatar
i'm having the same problem
kevbone
07-22-2020 07:28 AM
joshiebdapimp
05-27-2020 01:33 PM
tdenneson
06-08-2012 06:08 AM
vanser3004
Honda Civic (2001 - 2005)
05-31-2010 04:46 PM
Accordn95
06-25-2007 04:25 PM
Quick Reply: 97 Accord EX 2.2 A/C compressor clutch won't engage
