the ac on my honda civic 2002 will not work
Old 05-28-2012, 02:40 PM
JuanRocio's Avatar
Default the ac on my honda civic 2002 will not work
the ac on my honda civic lx 2002 works for a small period of time in the morning i turn on my car the ac willwork for a good 20 min the compresor shuts down and the rpm on my car goes up if it is the middle of the day and it id over 70 the ac will not come on what can be causing this problem is it the compresor on the clutch i know its not the relays i just replaced them and had no improvement
Old 05-31-2012, 12:17 PM
dpetro1's Avatar
Default Re: the ac on my honda civic 2002 will not work
have you checked the refrigerant levels? the compressor will turn off if the pressure is too low
Old 05-31-2012, 04:12 PM
02sia2's Avatar
heat equals pressure pressure equals a/c not working check your condenser fan and make sure it's working check your freon levels to make sure your a/c compressor didn't purge freon out and if it did purge you have to replace the valve
Old 05-31-2012, 05:50 PM
eviee1973's Avatar
Likely the thermal protector doing its job, something causing it to activate due to getting too hot.
Old 05-31-2012, 07:59 PM
j13
j13's Avatar
Agreed^ there is a switch that shuts down the a/c. You gave a leak somewhere in the system. Go to an a/c specialist and they can track down the leak, vac the system and refill
HondaNoviceMan
Honda Civic (2006 - 2015)
06-26-2018 02:28 PM
David Guevara
19
04-09-2016 06:44 AM
ham
08-29-2013 08:10 PM
Erasmus
04-14-2013 07:02 AM
KGNickl
05-01-2008 01:59 PM
Quick Reply: the ac on my honda civic 2002 will not work
