JDM B20b with p8r
Old 05-13-2012, 04:56 PM
blackcherry's Avatar
Default JDM B20b with p8r
Hey-
I have a quick question regarding B20s. I have the JDM B20b high compression motor which should be 9.6-1 compression. I found a good deal on a P8R B20 head so I want to know if putting the p8r head on will change my compression ratio? If so, do you know what it will be? If it drops it at all I may look into getting the head milled at the machine shop to compensate for the loss. Thanks guys
Old 05-13-2012, 09:01 PM
Brrraaaap!
Blaze45's Avatar
Default Re: JDM B20b with p8r
You could PM Irev210 or look for his B20 thread he made about the differences. I would imagine that if you switch heads that the CR would not change as the only difference I recall is that the Z had PHK pistons while the B did not.
If the head casting code is the same on both heads, I would assume that they are the same and CR would not change, but thats just me.
Old 05-14-2012, 09:01 AM
Gunmetal_B20_Hatch's Avatar
the P8R head has a 47cc combustion chamber... The B20 should be 45cc. You will lose a bit of compression, but IDK how much exactly. I would guess abuot 2-3 tenths.
You could deck the P8R head and maybe bring your CR back to like it was.
Old 05-14-2012, 11:04 AM
Awesome info. Thank you. What HG (OEM only) should I run with that setup? P8r, b20b hi comp, or are they the same?
Old 05-14-2012, 06:20 PM
something w/ 84mm bore... should be any b20
Old 05-15-2012, 07:11 AM
That works, I would think a b20z OEM HG will be one of the cheaper and easier ones to buy.
Timothy Yhtomit
02-07-2018 06:42 PM
muffler man
34
07-03-2009 11:53 AM
B20 Civic
08-02-2008 10:25 AM
Jurassic Four
06-25-2004 06:58 AM
Dammit_Dan_954
04-15-2004 07:44 PM
Quick Reply: JDM B20b with p8r
