Engine running a little hot 94 civic ex
Old 05-11-2012, 07:24 PM
MikesEJ1's Avatar
Default Engine running a little hot 94 civic ex
after the engine warms up,the coolant temp gauge goes up a little and comes down back to normal.It does not overheat,burn/loose coolant,or smoke and the rad fan and condensor fan both work.Also when its hotter than normal if you rev the engine to 2,000-3,000 rpms it cools back down to normal.not sure if its the thermostat stuck or the water pump is worn and not cooling properly.Any tips or info would be great,thanks
Old 05-11-2012, 08:02 PM
CivicBlacksheep's Avatar
Default Re: Engine running a little hot 94 civic ex
Does your fan come on? When last have you changed your coolant? Typically that symptom would be a weak thermostat spring or a sticking thermostat.. If the water pump was bad, there would usually be an indication of water loss or a growling noise from pulley (behind timing cover)
Old 05-12-2012, 03:31 AM
furious94ls's Avatar
Has the waterpump ever been changed?
Old 05-12-2012, 05:08 AM
mathai's Avatar
im having the same issue. Hoping to find solutions.
Old 05-12-2012, 05:19 PM
MikesEJ1's Avatar
changed the thermostat today and bleed the coolant and its a little better.The gauge rises a fraction of what it used to...but when the fan comes on it cools back down.Also when its running hot if you turn the heat on it cools down right of way.hmmmm maybe I have to bleed it better or possible poor coolant flow like a clogged radiator?
Old 05-12-2012, 05:34 PM
Old 05-12-2012, 05:44 PM
MikesEJ1's Avatar
well i have to check the water pump,I'm not sure im the third owner.it doesn't leak or make noise but it still might not be cooling the system right i guess
Old 05-12-2012, 05:45 PM
MikesEJ1's Avatar
also when the engine was hot i took the radiator cap off and no coolant sprayed out,like it was under no pressure...I don't think thats normal
Old 05-12-2012, 08:33 PM
Maybe your radiator cap is bad, it might not be holding the correct pressure... Do a pressure test... 15lbs
Old 05-13-2012, 03:13 PM
MikesEJ1's Avatar
well it turned out my radiator cap was broken
the part of the cap that creates pressure was broken off.I bleeded the cooling system 3 times and there are tons of air bubbles coming out,but was else can cause that much air in the cooling system?
Flipmonkey
09-30-2013 06:54 PM
thegatekeeper14
12-13-2009 09:25 AM
glbtrvlr09
04-13-2009 02:41 PM
alexthegrinch
10-09-2008 11:02 PM
christiian
18
07-16-2006 12:03 AM
Quick Reply: Engine running a little hot 94 civic ex
