Crankshaft Position Sensor
Re: Crankshaft Position Sensor
Yes, it's one of the most critical components for the ecu to be able to operate your ecu. Chances are, the wiring has been damaged or just rotted away as old as it is.
code 4 - crank sensor is inside the distributor - most likely your distributor is bad, if the wiring is o.k.
quik89
11-30-2003 06:43 PM
sander
04-25-2003 07:46 AM
