ABS light on....
Old 08-29-2013, 10:42 PM
  #26
stallion15's Avatar
Default Re: ABS light on....
i pulled the 15 amp and the 20 amp abs fuse for 3 seconds each. abs was off for a day, then came back on then turned off for a day. i think next time, i'm going to just pull the 15 amp fuse for 3 seconds.
Old 08-30-2013, 11:30 PM
  #27
MM Gruppe B
MAD_MIKE's Avatar
So your ABS light came on and you did not check the codes?
Old 11-07-2013, 12:44 PM
  #28
G Tiz's Avatar
Originally Posted by Lost Again
First thing I would do is clean the "ring" and the sensor...brake cleaner and a rag. Next, hope you have a volt meter, remove the connector and measure the resistance (sensor side)? What do you get?
...ps just so we are all clear. Right rear on a us accord is the pass/right side of the car.
Hey Lost Again, I've got the ABS light on. Tried jumping the connector- but no flashing, nothing- just a solid ABS the whole time from the moment I turn the car on (whether or not I pump the break to start, etc). So I cleaned the speed sensors and then stuck the multimeter ends into the speed sensor connector and both front speed sensors read 1.5 ohms. Is that good or bad? Where should I go from there? Thanks!!
Old 11-07-2013, 09:13 PM
  #29
HonBeer's Avatar
if it abs is so bad then why is it standard ON ALL NEW cars? You just don't know how to use it. Knowledge is the key to life!
Cheers!
Old 11-10-2013, 03:27 AM
  #30
Lost Again's Avatar
What did the "other" lights do when you jumped the connector?
Did you test the rear wheel sensors. Is the fluid level in the abs res full.
Krusty_the
03-28-2009 04:01 PM
ramz7887
03-22-2007 07:51 PM
integ3
12-05-2006 10:06 AM
DC5 Type-R
03-08-2002 05:52 PM
Quick Reply: ABS light on....
