Race only brake pads; questions, complaints, recommendations.
#101
Re: Race only brake pads; questions, complaints, recommendations.
Email this guy right here >>>>> tim@racebrakes.com Tell him David Martel gave you the contact info, tell him you race NASA or SCCA or whatever and ask what he can do.
You are then hard wired into the production guy at Porterfield Brakes in Costa Mesa, CA. The part number being RC503 for an ITR caliper. And the fronts want Raybestos pads in the ST43 compound.
#102
I needed a set of the Raybestos pads (RC503 in ST43 compound), so I e-mailed Tim, but had not got any reply, so I called him at 949-548-4470 per the website http://racebrakes.com/ and he gave me a nice discount vs the regular advertised online price. He said to just give him a call instead of e-mailing him if you need a set of pads, so he can ask questions if needed. - Jim
Astonishing customer service.. just remarkable.
Like Jim said.. don't email Tim.. just call him, it will absolutely be worth your time.
#103
I've tried many pads (not the raybestos though) and settled on Hawk DTC-60's. I was very happy with that pad on stock caliper/rotor.
#104
The DTC's are pretty good right up until they're not:
Picture of common problem with these pads from the first page:
#105
We have been running the DTC 60 front and DTC 30 rear for 3 years now. Never have we had a pad fail like that or fail in anyway. They say they fixed the problem and id say they have. Ive seen one neon do that but later found out they need a thicker backing plate to truly fix that problem.
#107
I had the chance to test out the Project Mu Sintered metal pads last weekend at Buttonwillow. The car is a 93 Civic HB with ITR calipers and Mini Cooper 11 inch rotors.
http://project-mu.co.jp/en/products/pad_sin.html
These pads are designed for high heat/endurance races. They have a very high metal content and will work great for anyone doing longer stints in their cars.
The cold bite is surprisingly good, but you can definitely tell these pads need heat. The brakes felt much better at the end of a 25 minute session then they did in the start.
Once warm, the bite is good, not too aggressive (less aggressive than Hawk HT-10, last pad I used)
These do have great modulation and are very sensitive to your input. You can feel the pad progressively grab harder long before they lock up. This was nice as it allowed me to try different braking techniques on a track I am very familiar with.
To me the best part about these was that because they are designed for endurance use. if they are used for shorter stints, the pad life is great! After 2 days. (7 session, 20-25 minutes each) each pad only lost about 0.5mm of compound. This also results in less dust.
I was expecting these to be much louder but they were surprisingly quiet, even cold.
Overall I give these 2 very big thumbs up. I am glad that I had a chance to try them out!
Pictures of the dust after 2 days, and rotor after 2 days.
#108
#109
I haven't needed to run them yet but I will at the upcoming event on the 20th. I'm looking forward to them!
#110
Ok, understand. My method is to always use bedded, seasoned pads on new rotors, or conversely, bedded rotors on new pads. That combo is my silver bullet to avoid shudder etc on new stuff.
#111
It's 2021, I'm sure there are some new pads out there now. I just ordered the ASR AP kit for my time attack car and am trying to decide on pads. The big three I'm looking at are Ferodo DS3.12, Hawk DTC-60, and Raybestos ST-43s. Does anybody have this same kit and can offer some feedback?
#112
I've used several of the Raybestos ST-xx compounds and just recently Hawk DTC-60's. Never used a Ferodo, but the Raybestos pads are awesome; Hawk, not so much.
#113
Curious what it is about the DT60s you don't like. I've used the Blue 9012s for a few years and they are phenomenal, very predictable, and decent even when cold, although I have always needed rotors when I need pads. Haven't really considered the more hardcore pads as my brakes won't hit over 1000 F on track (light and low powered EF)
#114
I spent 1.5 seasons on the ST43 (same set of pads AND rotors). you DO NOT jump on the brakes with these pads. they have too much initial bite... but what you can do is squeeze them (harder and harder after you first press the brake)... this modularity was very conducive to wheel to wheel racing where i need to pass/lap miatas, E30s, and the back end of the ST and Spec3 groups. I couldnt always hit my marks, there was a car there or whatever... but i always had/have confidence in braking... did i mention 1 set of pads and rotors for 1.5 years?
#115
I have no experience with the Ferodo, but have run the DCT-60 and ST-43's on our endurance EG hatch on centric blank rotors with Wilwood DPHA calipers. The DTC-60's had too much initial bite and poor modulation. They did not last for a 16-hour weekend and provide poor rotor wear. The ST-43's had less initial bite but good modulation and excellent consistency. Pads are ~50% worn after a typical two race endurance weekend. The ST-43's do not wear the rotors at all. We replace the rotors after several race weekends due to heat checking on the surface.
For my last order, the ST-43 compound was not available, so we will be trying the ST-45's next race.
#118
anyone have feedback on the ST45s?
i'm about to go from the EM1 (2550lbs) on 986 brakes with ST43s to an 8th gen (2750) with TL-S brakes .... is the extra 20lbs worth going from 43s to 45s? i think she's going to be a big girl... AND i should be 1-2mph faster on the straights.
#119
I like the 45's, more initial bite than the 43's which I always thought they lacked (and was surprised you said they had too much). Still rotor friendly and high heat tolerant, great wear.
#120
i could easily jump on the brakes with ST43s and lock them up. the bonus was they would let go (unlike the DTC60s) and you can squeeze them (unlike the DTC60s) to some crazy braking pressures with great feel.
J Ritt
06-09-2010 08:24 AM
FormulaIntegra
41
02-04-2010 06:15 AM
