Repacking bearings already pressed in
Old 05-08-2012, 03:33 PM
  #26
known's Avatar
Default Re: Repacking bearings already pressed in
When I did my thread on this I used koyo bearings and repacked them with amsoil 2000 high temp racing grease.
Old 05-09-2012, 10:16 AM
  #27
s1ngle's Avatar
I need something that can be mixed with the stock grease
Old 05-09-2012, 01:13 PM
  #28
VTECIntegra9's Avatar
an oem grease is a compromise between warm temps, cold temps, and low friction (this is more from the seals & design tho). I might be able to ask one of the bearings guys at work what type of grease is used. It's typically not a synthetic, however I'm not sure that it would be a problem to mix.
Old 05-09-2012, 03:39 PM
  #29
The Destroyer's Avatar
Why not use a grease gun with a grease needle?
Like this:
Old 05-09-2012, 03:48 PM
  #30
known's Avatar
I guess, the problem with that is if you add an excessive amount you are going to cause even more issues.
redlinetuning
Suspension & Brakes
11
04-06-2014 02:30 PM
crashsvg
01-09-2014 05:30 AM
adubaz7
10-03-2007 07:49 PM
IN VTEC
03-18-2006 08:40 PM
Quick Reply: Repacking bearings already pressed in
