P0108 MAP sensor curcuit high voltage, need some help
Old 04-19-2012, 09:22 PM
steadysupreme's Avatar
Default P0108 MAP sensor curcuit high voltage, need some help
I currently have a P0108 code and had already replaced the MAP sensor but it still have the same P0108 code. Also, i guess the rough idle problem is originated from the P0108 code too? Sometimes, the idle dipped to a point that will shut off the car.
On top of that, someone mentioned it might be related to the Engine Coolant Temp. My ECT gauge on the cluster is always off. Off meaning, when it is even normal operating temp, the gauge is no where close to the middle. Is there a way to check the ECT?
By the way i did the first very test using the scanner.
***I got only 28kpa instead of 101kpa***
Anyone can help me out?
Old 04-19-2012, 10:44 PM
mr_munro's Avatar
Default Re: P0108 MAP sensor curcuit high voltage, need some help
You might get a bit more help if you post this in the Tech Section
Old 04-20-2012, 11:23 AM
Ok i will try that, but i can't believe no one can help me out here?
Old 04-20-2012, 04:36 PM
Hybrid96EK's Avatar
The flow chart says you SHOULD get LESS the. 101kpa... Which you did. So using the flow chart, you have no current issue but should check wiring for a short as it says.
Bswapped
06-20-2015 02:22 PM
steadysupreme
04-20-2012 02:27 PM
oakman513
07-24-2011 09:31 AM
chrysler kid
09-28-2004 07:24 PM
Quick Reply: P0108 MAP sensor curcuit high voltage, need some help
