Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 04-19-2012, 01:52 PM   #1
JDMEF
JDMEF's Avatar
Default Check Engine Light
Hey wassup i have a 91 ef and my check engine light is on.. i read the code on the ecu and it blinks 6 times. ever since the light came on my gas milage has been sucking. i know in theowners manual says 6 blinks is temperature gauge and something else i cant remember but i tried reseting the ecu by disconnecting my battery for like 20 minutes but its still there. my book says take car t dealership but nahhh.. so what could it be or what can i do ? thanks
JDMEF is offline   Reply With Quote
Old 04-19-2012, 04:25 PM   #2
CRX Toad
CRX Toad's Avatar
Default Re: Quick question
PLEASE BE SPECIFIC IN YOUR TITLE "QUICK QUESTION" HELPS NO ONE THAT MIGHT HAVE THE SAME ISSUE.
[B]Hondworks[/b]
Need a write up on how to fix your CRX [b]cracked climate control[/b], PM me
1990-1993 Accords parting out
1991 CRX HF parting out
PM me for any parts
EG Sedan Tail Lights $60 shipped
CRX Toad is offline   Reply With Quote
Old 04-19-2012, 05:22 PM   #3
neophish
1990 Honda CRX
neophish's Avatar
neophish
Send a message via AIM to neophish
Default Re: Check Engine Light
ok, if code 6 is a temp issue, what is the temp gauge reporting? when was the last time you flushed the coolant? or changed the thermostat?
neophish is offline   Reply With Quote
Old 04-19-2012, 05:53 PM   #4
TeamRedline89Hatch
TeamRedline89Hatch's Avatar
Code 6 - Coolant Temp Sensor. Check to make sure it is plugged in and the wire isn't broken. If all is good, they are like 20$ at Auto Zone.
Originally Posted by STDClayton
Dude, it's cool. We ALL know that Mary-Kate and Ashley were at their prime when they were around 3 years old. Don't even act like you guys never accidently masturbated to old re-runs of Full House.
TeamRedline89Hatch is offline   Reply With Quote
Old 04-20-2012, 06:35 AM   #5
jlicrx
jlicrx's Avatar
code 6 is for the temperature sensor (TW) for the ECU, not the gauge - gauge sensor doesn't give a CEL and a code - TW sensor affects injector timing and duration, ignition timing, idle control, etc. - TW sensor is located on the end of the head below the distributor - has a 2-wire connector with red/white and green/white wires - either the sensor is bad or you have a problem with the wires or connector
ZCspeed Racing
jlicrx is offline   Reply With Quote
Old 04-20-2012, 05:26 PM   #6
Kayita
Hey, this is someone else. My Check Engine LED for 2004 Honda Accord LX manual is not turning on. Just bought the car, hoping the wire was only disconnected. Do you have pinout for ECU (signal out) and Cluster (signal input) pins for this LED Engine light? thanks in advance.
Kayita is offline   Reply With Quote
Old 04-20-2012, 10:01 PM   #7
JDMEF
JDMEF's Avatar
Thanks everyone for your help i relly appreciate it but my problem is finally solved! thanks to jlicrx thank you so much dude
Old 04-21-2012, 08:57 AM   #8
skill178
1991 Honda Civic
My Garage
skill178's Avatar
Can anyone lemme know which wire goes on which prong? My clips broke and I have two little clips on the wires now but Idk which wire goes on which.
skill178 is offline   Reply With Quote
Old 04-21-2012, 03:35 PM   #9
JDMEF
JDMEF's Avatar
@skill178 the red wire is facing the clip, and the green wire goes below the red one
Old 04-21-2012, 03:37 PM   #10
JDMEF
JDMEF's Avatar
@ kayita first make sure the ecu cover isint put on backwards. i thought mine didnt work either but then i took the cover off and discovered that the previous owner had taken the cover off and accidentally put the cover back on facing the wrong way. check that first cuz it happend to me lol
Old 04-23-2012, 04:22 AM   #11
Kayita
The thing is, I put put in another ECU, used. Light still not coming on when Ignition is ON, not start. Car runs fine. which is the position it should be to test all cluster lights. My State inspection is comming up, got to have this light lid. Need pin-outs for both ECU and Cluster. Anyone have them? 2004 Honda Accord LX, manual transmission.
1993, 2001, accord, blinking, check, coolant, ecu, engine, honda, lamp, light, located, sensor, temperature, times
