Timing belt replace, not tight.
Old 04-16-2012, 01:23 PM
yankie_1132's Avatar
Default Timing belt replace, not tight.
I recently did a timing belt/water pump replacement on my 2001 accord lx 2.3l. How do you tighten the belt properly with the auto tensioner? It's weird compared to other cars that have a spring load.
Old 04-16-2012, 02:24 PM
fubuallstar's Avatar
Default Re: Timing belt replace, not tight.
i just loosen the tension bolt a lil and retighten it while guiding tensioner to the desired tighteness then i tighten the support screws on the lil handles. go on youtube theres a few 6th gen how to's so you can see what im talking about
Old 04-17-2012, 03:33 AM
H-T Order of Merit
TouringAccord's Avatar
should be the same procedure as the one outlined in the timing belt write-up in the faq thread.
chahsiubow
12-14-2007 10:01 PM
batlground1
10-16-2006 02:21 PM
grngsr01
03-14-2005 05:19 AM
SilverEk3dr
01-29-2003 11:27 AM
Quick Reply: Timing belt replace, not tight.
