How do I check codes in a 1991 accord lx??
Old 10-11-2002, 03:42 PM
Monty's Avatar
Default How do I check codes in a 1991 accord lx??
Its a friends car so Im a little confused. Do i jump the little blue connector above the glove box and check engine light will flash? Or is it like the civic / integras where you get an led? I pulled the carpet back to find no led
very confused. Thanks for any help,
Monty
Old 10-11-2002, 05:21 PM
bill-71SS's Avatar
Default Re: How do I check codes in a 1991 accord lx?? (Monty)
jump the conn.
Old 10-14-2002, 12:39 PM
AccordVtec's Avatar
Just turn the key over, peel back the carpet under the passenger side.
Then there is a hole through the cover over the ECU, just look at the hole and it will blink, over, and over, count the blinks!
Old 10-14-2002, 01:16 PM
GimpyAccord's Avatar
Default Re: How do I check codes in a 1991 accord lx?? (AccordVtec)
I think 90 was the last year on the Accords to have LED. My 91 LX you jump and the check engine light will proceed to blink your code.
Old 10-14-2002, 02:21 PM
Monty's Avatar
Default Re: How do I check codes in a 1991 accord lx?? (GimpyAccord)
yeah no led in 91 I'll try the jumper. Does it store codes though?? The check engine light is intermittent(sp)
thanks
Old 10-14-2002, 05:22 PM
I think it stores codes for up to 10 or 15 'running cycles' aka. key run/off ... don't quote me on that
Old 10-14-2002, 08:26 PM
Howitt's Avatar
if your having trouble finding the jumper let me know it took me 2 hours to find it the first time, and the haynes manual was useless, there was like 4 guys looking for it eventaully found it under the kick panel, damn near in the door
Old 10-18-2002, 03:28 PM
Monty's Avatar
Default Re: How do I check codes in a 1991 accord lx?? (Howitt)
Ok finally got back to working on it.
Code 17 = VSS
Is the Vss behind the speedometer?
Also The "S" (speed shift light) is flashing 4 times. Is this another code?
Thanks for any help
Old 10-18-2002, 04:01 PM
Chiovnidca's Avatar
Code 17 = VSS
Thanks for any help
Probably a bad speed sensor. It's on the transmission.
90civicSiRacer
10-01-2007 02:35 PM
aging-accord
07-21-2007 09:20 PM
2kTeg
01-24-2006 05:31 PM
abird
08-03-2004 09:09 PM
Quick Reply: How do I check codes in a 1991 accord lx??
