Go Back   Honda-Tech > Honda and Acura Technical Forums > Tech/Misc
Old 04-09-2012, 12:40 PM   #1
boostjunkieee
boostjunkieee's Avatar
Send a message via AIM to boostjunkieee
Default 94 Accord EX Problem with Turn Signals/Hazard Lights
I cant seem to get either the turn signals or the hazards to work on my 94 Accord EX. I've replaced all the bulbs, replaced the turn signal relay, replaced the combination switch in the steering column, checked all the fuses and still nothing. None of the bulbs in the front or rear will light, neither of the turn signal lights on the gauge cluster light, no clicking noise.....nothing at all. Headlights, reverse lights and brake lights all work fine. I tried searching for the hazard flasher but I cant seem to find it, does anyone know where its located on this car? Thats about the only thing left to change. Any input or help would be greatly appriciated.
95 Civic - SOHC Turbo
*373whp 315ft/lbs*
boostjunkieee is offline   Reply With Quote
Old 04-09-2012, 04:21 PM   #2
fcm
Old Fart
fcm's Avatar
Default Re: 94 Accord EX Problem with Turn Signals/Hazard Lights
Hazard lights and signal lights use the same, "flasher". [Signal/Hazard Lights Relay] power for both the hazard lights and signal lights go through the hazard switch, all the wiring after the hazard switch is common for signal and hazard lights.
Pull the hazard switch and test for a 12V+ constant, [hot at all times] hazard lights power, and a 12V+ switched, [hot in run and start] signal light power.
If you have both, the problem is the hazard lights switch, replace it. 94
RIP Zack 2001-2013, my best friend.
fcm is offline   Reply With Quote
Old 08-20-2012, 11:06 AM   #3
DC2MeCZoom
Im having the same issue, did you ever figure it out? im not getting no power from where the turn signal relay plugs in so might it be the wires? i change the switch itself like a month ago
DC2MeCZoom is offline   Reply With Quote
Old 12-12-2012, 03:20 PM   #4
Hektor
1992 Honda Civic
Hektor's Avatar
Hello, Iam having the the same issue with my accord. I replaced the hazard switch and the combination switch in the steering column. The hazards work now but the turn signals dont.
were you able to fix your issue?
Were would the turn signal relay be?
"One good thing about music, when it hits you, you feel no pain."
-Bob Marley-
Hektor is offline   Reply With Quote
Old 12-12-2012, 05:52 PM   #5
Crx_owner_20
Crx_owner_20's Avatar
And.. here you go.
Crx_owner_20 is offline   Reply With Quote
1994, 94, accord, blinker, hazard, honda, light, lights, relay, replace, signal, signals, switch, turn, working
Similar Threads
95 Accord Ex turn signals/ hazards won't work??? TJaccord95 Honda Accord (1990 - 2002) 1 07-01-2014 09:35 AM
95 Civix DX, L turn signal is dim and blinks fast, and hazards don't work. NikiFlash Honda Civic/Del Sol (1992 - 2000) 12 02-23-2014 09:20 PM
Turn Signals inop but hazards work choppyEG Honda Civic/Del Sol (1992 - 2000) 2 10-12-2013 05:36 PM
2004 Honda Accord EX Sedan turn signal and hazard light problem Emily2809 Honda Accord & Crosstour (2003 - Current) 1 06-04-2013 06:30 PM
Turn Signal Electrical Problem frankiecutz Acura Integra 2 02-11-2013 04:50 PM
