1990 Honda civic EF brake lights
Old 04-04-2012, 07:26 AM
shiroun's Avatar
Default 1990 Honda civic EF brake lights
Alright guys. I got a problem.
Break lights stay on.
I tried the little blue crayon fix, no joy.
Tightened the break light switch, no joy.
Unplugged the break light plug, and the break lights were still on.
How do I fix this.
Old 04-04-2012, 08:39 AM
PHANTOM MENACE
24TEN's Avatar
Default Re: 1990 Honda civic EF break lights
I have no idea what that is...
Have you tried actually pressing the switch?
Brake light plug? Or the plug on the brake light switch? If they are still on with the switch disconnected then there has to be a short somewhere.
How do I fix this.
This would be my first thing to check:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/brake-lights-stay-how-i-fixed-them-2254546/
Old 04-04-2012, 08:55 AM
shiroun's Avatar
Default Re: 1990 Honda civic EF brake lights
Follows the directions in that thread, its what I meant with my original line. It didn't work. How would I diagnose a short?
Old 04-04-2012, 09:01 AM
PHANTOM MENACE
24TEN's Avatar
Hard to explain, even worse if you're not good with electrical stuff already. If it were me, I'd look up the wiring diagram and see if there's anything up/down stream between the switch and battery as a source of power. Then I'd get in there and start looking around for visual issues. I'd probably use a multimeter to see if I can track down the source. I hope someone else has an easier way to help you out because I doubt anything I said helped at all.
Old 04-04-2012, 11:06 AM
shiroun's Avatar
Alright, well here's what I did.
The break stopper pedal is brand new.
The break switch (with the plug on the back of it, has the little pressure switch on the front that hits the break stopper) is fully depressed, I even made sure by loosening the nut and then tightening the switch.
I tried unplugging the plug on the back of said switch.
I also checked all the fuses on my dash fusebox, nothing is blown.
I'm very lost. meh.
Old 05-14-2012, 04:13 PM
shiroun's Avatar
Okay.
I put a new brake stopper pad in, and that didnt solve the problem.
So then I unplugged the plug that goes into the brake stopper switch -- but to no avail.
I'm at a loss for options here. I figure i might have a short -- but that would bypass the switch???
Old 05-24-2012, 11:31 AM
shiroun's Avatar
gonna rebump. Still got this problem.
Anyone got the wiring diag?
Old 05-24-2012, 11:48 AM
TearSDMF89dx's Avatar
could be a bad ground feeding back power from another circuit
Xzay01
Lighting
06-14-2013 08:53 AM
josephb
07-31-2011 01:16 PM
disboiflaco
03-14-2011 05:45 PM
neogenesis2004
03-03-2009 04:21 PM
Aralliius
10
08-20-2007 11:20 PM
Quick Reply: 1990 Honda civic EF brake lights
