2002-2006 Honda CRV Performance Thread
Old 04-03-2012, 02:27 PM
norcalem2's Avatar
Icon7 2002-2006 Honda CRV Performance Thread
2002-2006 HONDA CRV Performance Parts List
This Thread was started for people who want to upgrade their performance on the 2nd Gen CRV. There is limited a mount of mods for this generation unlike the first Gen CRV there is long list of mods that you can do. So I tried to make it easier for everyone to find parts for the 2nd Gen CRV. If anyone has more stuff they want to add to this list please post on this thread and I will edit this main one.
SUSPENSION PARTS
FYI
Spring rate conversions kg/mm to lbs/in
This conversion rate is close as possible! It is just something for you guys to be able to gauge what spring rate is best for you style of driving and what suspension you should choose!
1lb = 0.45359237 kg
1in = 25.4mm
.45359237 / 25.4 = .017857967322834645669291338582677
1lb/in = .01785 kg
kg/mm to lbs/in
Green area: Street Use or Daily Driving only (Do not drive all the way slam down)
Blue area: Street and Track on weekend (You can slam car down)
Red area: Track only (Too stiff for daily driving)
2.0 = 112
2.5 = 133
3.0 = 168
3.5 = 196
4.0 = 224
4.5 = 252
5.0 = 280
5.5 = 308
6.0 = 336
6.5 = 364
7.0 = 392
7.5 = 420
8.0 = 448
8.5 = 476
9.0 = 504
9.5 = 532
10.0 = 560
11.0 = 616
12.0 = 672
13.0 = 728
14.0 = 784
15.0 = 840
16.0 = 896
I found this on another forum. I hope this will help you guys choose what spring rate is best for you style of driving!
Lift Kit
CCM OFF Road Lift Kit
Link: http://www.ccmoffroad.com/shop/index...ct_detail&p=18
CRV 2002-2006
2003-2009 Honda Element
This kit said for Honda Element but will fit CRV model number cross reference.
SHOCKS
BILSTEIN HEAVY DUTY SHOCK HONDA CR-V 2002-2006 FRONT LEFT
SKU:BIL-35-107460
BILSTEIN HEAVY DUTY SHOCK HONDA CR-V 2002-2006 FRONT RIGHT
SKU:BIL-35-107477
BILSTEIN HEAVY DUTY SHOCK HONDA CR-V 2002-2006 REAR
SKU:BIL-24-107488
KONI SPORT YELLOW SHOCKS HONDA CR-V 2002-2004 FRONT
SKU:KON-8641-1458SPORT
KONI SPORT YELLOW SHOCKS HONDA CR-V 2002-2004 REAR
SKU:KON-8040-1320SPORT
SPRINGS
H&R SPORT SPRINGS HONDA CRV 2002-2006
SKU:HNR-51821
EIBACH PRO KIT LOWERING SPRING HONDA CR-V 2002-2003
SKU:EIB-4064.140
HONDA CRV LIFT, OLD MAN EMU
OME2538
HTTP://WWW.ROCKY-ROAD.COM/HONDASUS.HTML
COILOVERS
KSPORT KONTROL PRO COILOVER DAMPER KIT HONDA CRV RD5 2002-2006
SKU:KSP-CHD120-KP
CAMBER KIT
EIBACH PRO-ALIGNMENT FRONT CAMBER BOLT KIT 16MM HONDA CR-V 2002-2006
SKU:EIB-5.81280K
SPC REAR CAMBER ARM KIT (CAMBER: -2.00 DEGREE TO +4.00 DEGREE) HONDA CR-V 2002-2006
SKU:SPC-67430
SWAY BAR
ADDCO 2002-2006 HONDA CRV - REAR SWAY BAR (7/8" DIAMETER)
2339
STRUT BAR
NEUSPEED UPPER STRUT BAR
35.20.75P
Lower Control ARM LCA
these will fit
RSX 2002-2006
BRAKES
PADS
HAWK HPS PERFORMANCE STREET BRAKE PADS HONDA CR-V 2002-2004 - REAR BRAKE
SKU:HWK-HB145F.570
HAWK HPS PERFORMANCE STREET BRAKE PADS HONDA CR-V 2002-2004 - FRONT BRAKE
HWK-HB393F.665
2002-2004
EBC 6000 Series Greenstuff Truck/SUV Brakes; Disc Pads; Front;
DP61655
EBC 6000 Series Greenstuff Truck/SUV Brakes; Disc Pads; Rear;
DP6781/2
EBC 7000 Series Greenstuff SUV Supreme Compound; Disc Pads; Front;
DP71655
Yellowstuff Street And Track Brake Pads; Front;
DP41655R
Yellowstuff Street And Track Brake Pads; Rear;
DP4781/2R
2005-2006
DP61193/2
DP61655
DP71655
DP41193/2R
DP41655R
ROTORS
POWER SLOT PERFORMANCE SLOTTED BRAKE DISC ROTOR HONDA CRV 2002-2004 - FRONT LEFT
PWR-126.40036SL
POWER SLOT PERFORMANCE SLOTTED BRAKE DISC ROTOR HONDA CRV 2002-2004 - FRONT RIGHT
PWR-126.40036SR
POWER SLOT PERFORMANCE SLOTTED BRAKE DISC ROTOR HONDA CR-V 2002-2004 - REAR LEFT
PWR-126.40058SL
POWER SLOT PERFORMANCE SLOTTED BRAKE DISC ROTOR HONDA CR-V 2002-2004 - REAR RIGHT
PWR-126.40058SR
2002-2004
EBC USR Series Sport Slotted Rotor; Front; 11.1 in. Dia.; Set of Two;
USR7116
EBC USR Series Sport Slotted Rotor; Rear; Set of Two;
USR1474
Rotor; EBC 3GD Series Sport Slotted Rotors; Set of Two; Front; 11.1 in. Dia.;
GD7116
Rotor; EBC 3GD Series Sport Slotted Rotors; Set of Two; Rear;
GD1474
Rotor; EBC UPR Series Premium OE Replacement Rotors; Each; Front; 11.1 in. Dia.;
UPR7116
Rotor; EBC UPR Series Premium OE Replacement Rotors; Each; Rear;
UPR1474
2005-2006
EBC USR Series Sport Slotted Rotor; Front; 10.1 in. Dia.; Set of Two;
USR7124
EBC USR Series Sport Slotted Rotor; Front; 11.8 in. Dia.; Set of Two;
USR7127
EBC USR Series Sport Slotted Rotor; Rear; 12.0 in. Dia; Set of Two;
USR1401
Rotor; EBC 3GD Series Sport Slotted Rotors; Set of Two; Front; 11.8 in. Dia.;
GD7127
Rotor; EBC 3GD Series Sport Slotted Rotors; Set of Two; Rear; 12.0 in. Dia.;
GD1401
Rotor; EBC UPR Series Premium OE Replacement Rotors; Each; Front; 11.8 in. Dia.;
UPR7127
Rotor; EBC UPR Series Premium OE Replacement Rotors; Each; Rear; 12.0 in. Dia.;
UPR1401
BRAKE LINES
Techna Fit Steel Brake Lines
2003-2004 CR-V
30316
2005-2006 CR-V
30317
HTTP://WWW.TECHNA-FIT.COM/SUV.HTML
Engine Performance
Most K series mods can be used from other cars like the RSX/CIVIC SI K20 or TSX/Accord K24. The K24A1 motor which is found in 2nd gen CRV is a good base to add many different aftermarket modifications.
INTAKE SYSTEM
STOCK AIRBOX:
K&N Drop In AirFilter
E-2429
AFTER MARKET INTAKE
FUJITA SHORT RAM AIR INTAKE HONDA CR-V LX / EX / SE 2002-2006
SKU:FUJ-SR-191
K&N TYPHOON SHORT RAM AIR INTAKE SYSTEM HONDA CR-V 2.4L 2002-2004
SKU:KNN-69-0015
AEM Short RAM
69-0015TR
AEM Short RAM
69-0015TS
Exhaust System
02-06 CRV H-System OBX Catback
14-1603-2H
SuperCharger
http://www.arb.ca.gov/msprog/aftermk...es/amquery.php
EO Date: 2006-12-20
Manufacturer Name: Comptech Machine
Comptech Supercharger "CARB LEGAL"
2003-2005 CRV
350-078
JacksonRacing Supercharger
HOOD
VIS RACING CARBON FIBER HOOD OEM STYLE HONDA CRV 2002 - 2006
SKU:VIS-02HDCRV4DOE-010C
Lighting
Headlamp
Headlights
2002-2004
H4 Bulb
2005-2006
9006 lows
9005 highs
HID
ddmtuning.com
ROOF RACK
BRUSH GUARD
BULL BAR
TOW HITCH
Class III Hitch by "Curt"
Vinyl Wraps
3M Vinyl Wraps
http://autovinylsolutions.com/index....te=common/home
FAQ:
How to upgrade 2002-2004 to 2005-06 model.
Front Brakes:
All you need to do is purchase 05-06 Caliper Braket and Rotor. Its 1"inch larger in diameter than the 02-04 model.
Rear Brakes:
You need to change out the whole knuckle, rotor and caliper. "My opion is not to do the rear brakes its not worth the upgrade"
Can Civic Si 06-2011 rims fit my CRV?
Front: Needs spacers at least 4mm
Rear: Clears just fine
Lift KIT or Bigger Office Road tires?
Official H/T OFFROAD/LIFTED CR-V thread!*
https://honda-tech.com/forums/honda-cr-v-element-156/%2Aofficial-h-t-offroad-lifted-cr-v-thread-%2A-3118056/
What are stock tire size, offset, and Lug pattern?
2002-2004
205/70R15
+55 offset
5X114 Lug Pattern
2005-2006
215/65R16
+55 Offset
5X114 Lug Pattern
CRV Manual 6 gear MOD
Originally Posted by qwrty
http://hondasuv.com/members/showthread.php?t=40677
from element owners club:
Honda Element 6 speed Manual Transmission Conversion
Part numbers supplied are from a 2006 Acura TSX 6MT
The identical parts could be obtained from a 2006 Civic Si 6MT, but the part numbers will be slightly different.
I recommend both of these manuals:
Helms Honda Element Manual
Helms Acura TSX Manual
- Shifter mechanism parts -
Reverse shift piece 24240-PNS-000
Shift arm interlock 24430-PNS-000 (or modify the old one)
*5-6 gearshift fork 24201-RAS-000* NOTE: In at least one CRV and possibly in some later model Elements the Reverse shift piece may be welded to the Element's 5-Reverse shift fork, instead of being attached by a pin. In this case see step 3 below.
These parts are optional. The function of these parts hasn't been determined; however the transmission functions well without them. They may be necessary for reverse safety interlock.
* MBS arm 24412-PNS-000
* MBS arm spring 24413-PNS-000
* - added by MikeQBF. }
- Main shaft parts -
Mainshaft 6th gear 23590-RAS-A00
Needle Bearing (35 x 41 x 24) 91103-RAS-003
Collar (28 x 35 x 24) 23916-PNS-000
5-6 Synchronizer Sleeve Set 23626-PNS-315
- Countershaft parts -
Special bolt 90011-PPP-000
Countershaft 6th gear 23491-RAS-000
Procedure
Note: This is the procedure that I followed. This worked for me, however if there are mistakes or omissions I cannot be held responsible. There are several variations that will also work. Without proper experience it is possible to destroy the transmission if it is not reassembled correctly. It is important to inspect all parts and if there are any worn parts they should be replaced. Please use caution and common sense.
1. Following procedure in the Element Manual, remove the transmission. Note it is not necessary to remove the outboard joints of the driveshafts from the wheel hub. They can remain in place. Just remove the inboard joints from the transmission and intermediate shaft. Do remove the intermediate shaft.
2. Follow procedure in the Element Manual for disassembly of the transmission. Stop after the shifter and gearsets have been removed. Discard the reverse cam lock.
3. Drive out the pin connecting the reverse shift fork and the 5th gear shift fork. Discard the pin. Remove and discard the reverse shift fork. Replace with the new 6 speed reverse shift fork. **In at least one CRV and possibly some later model Elements the reverse shift fork may be welded to the 5th gear shift fork (rather than attached by a connecting pin). In this case you must order the TSX 5-6 gearshift fork 24201-RAS-000. Use this shift fork as a replacement for the stock 5th gear shift fork.**
4. Follow the procedure in the Element Manual for disassembly of the mainshaft. Remove the taper cone ring and associated distance collar, and discard. Remove 5th gear synchronizer, discard and stop. Follow the procedure in the Acura TSX manual for reassembly of the mainshaft. Press the new 5-6 synchronizer hub onto the mainshaft. Place the new collar and needle bearing on the mainshaft. Place the new mainshaft 6th gear over the needle bearing. Replace the ball bearing as directed.
5. Follow the procedure in the Element Manual for disassembly of the countershaft. The appropriate way to do this is to use a bearing puller and hydraulic press, but some people cheat. Other people find a local tranny shop may help with this step. Remove the special bolt (note - reverse threads). Remove the bearing, the shim, and the distance collar, then stop. Discard the special bolt and distance collar. Follow the procedure in the Acura TSX manual for reassembly of the mainshaft. Press the countershaft 6th gear onto the countershaft. Complete reassembly of the countershaft as directed.
6. Replace the shift arm interlock with the new interlock. Alternatively, the slot in the old shift arm interlock can be elongated by about 6mm (the width of the reverse select lever).
7. Follow procedure in the Element Manual for reassembly of the transmission. Do not re-install the reverse lock cam. Note: Be sure to install the speed sensor spacer (It is not a washer) in the correct order - Bolt, sensor, spacer, transmission.
8. Following procedure in the Element Manual, install the transmission.
9. Drive.
Things you should watch out for when purchasing 2nd GEN CRV
Originally Posted by Targa250R
If the oil is changed on a regular basis and the engine has never been run low on oil, it generally won't have probems. If the oil has been changed infrequently or the car has been run low on oil several times, chances are that the engine will have problems with the timing chain and/or the VTC system.
Some '02-04 CR-Vs are affected by a faulty A/C compressor, which explodes internally and then contaminates the rest of the system with particulate compressor innards, requiring the entire A/C system (or at minimum, several parts of it) to be replaced at great expense (anywhere from $800-2000 depending on labor costs and parts required).
Door lock actuators are a common failure. The lock cylinders in the doors tend to seize up also - I recommend squirting some lock cylinder lube in them on a regular basis to keep this from happening. The original primary oxygen sensor tends to go bad at some point and trip a Check Engine light; unfortunately it's pretty expensive.
Other than that, they hold up well. Of course you'll have the normal consumable parts go bad (sway bar links, bushings, ball joints, axles, brakes, tires, struts, etc.). These cars also tend to consume tires faster than most vehicles depending on driving conditions, so it's not a bad idea to buy tires with a treadwear warranty and rotate them as needed to validate that warranty.
Change the Dual Pump fluid in the rear differential every 30,000 miles to provent the diff from making growling noises during hard turns. Change the trans fluid every 30,000 also.
They're pretty good vehicles if they're taken care of (as with most Honda cars). If the car has a solid recorded service history and is in good shape, I wouldn't hesitate to buy it regardless of the mileage.
Maintenance Intervals
These are only recommendations of maintance intervals for your CRV.
Engine Oil 5w-20
Suggest to change you Engine oil every 3,000 miles even if you use Fully Syntheic oils. "Engine Oil is cheap compared to replaceing a motor"
Transmission
Auto: 4qts when backed up on ramps. "ONLY BY HONDA ATF FLIUD"
3qts on flat ground "ONLY BY HONDA ATF FLIUD"
Manual:????? can someone help me out on this information?
How often should I change the rear differential oil?
I suggest changing this every 10,000 miles if you drive your CRV aggressively.
You you drive your CRV normal you should change this every 30,000 or if your rear diferential starts to squeal or make a moaning sound.
You can change your oil yourself which is very simple takes only 10min
1. You will need 2 quarts of Dual Pump Honda fluid Only!!!!
2. Two washer plug rings which you can get at honda also.
3. Suggest to back your car up onto ramps on flat ground.
4. You will need oil pumper to pump back in the oil fuild after draining.
5. Spray off extral oil drips with Brake Cleaner.
CRV Specification
K24A1
Found in: 2002-2006 Honda CR-V Displacement: 2,354 cc (143.6 cu in)
Bore and Stroke: 87 mm x 99 mm (3.43x3.90 inches)
Compression: 9.6:1
Power: 160 hp (120 kW) @ 6000 rpm
Torque: 162 lb·ft (220 N·m) @ 5200 rpm
Rev limit: 7000 rpm
http://en.wikipedia.org/wiki/Honda_K_engine#K24A1
"Taken from Wikipedia"
The bigger and heavier second generation CR-V (Chassis Code RD4-RD7) was a full redesign, based on the seventh generation Civic, and powered by the K24A1 engine. North American versions of the new engine produced 160 hp (120 kW) and162 lb·ft (220 N·m) of torque. Per new SAE regulations, the same engine is now rated at 156 hp (116 kW) and 160 lb·ft (220 N·m). Despite the power increase, the new CR-V retained the fuel economy of the previous model, thanks in part to the engine's i-VTEC system. The newly developed chassis had increased torsional and bending rigidity, while the new suspension possessed front toe control link MacPherson struts and a rear reactive-link double wishbone; the compact rear suspension increased cargo space to 72 cu ft (2,000 l). The second generation CR-V was Car and Driver magazine's Best Small SUV for 2002 and 2003. Second generation CR-Vs in countries outside of North America were again offered in both 'low specification' and 'high specification' variants, with the latter featuring body-colored bumpers and fittings. It also now did not require the glass hatch to be opened before the swinging door. Changes between model years 2002, 2003, and 2004 were minor. The success of the CR-V prompted Honda to introduce an entry-level SUV, the Element.
It is reported that in late 2003, Honda took legal action against Shuanghuan of China accusing its Laibao SRV of copying the CR-V's exterior design.[4]
Facelift
Facelift Honda CR-V (Philippines).
In 2005, the CR-V received a mid-cycle refresh. The 2005 CR-V was now equipped with 16 inch wheels, the earlier models had 15 inch wheels. Visual changes included new taillights and headlights with clear indicators. The new headlights now have two separate H1 bulbs for low beams and high beams, the previous setup used H4 single bulb for both low and high beams. The taillights now used clear lenses instead of amber for the turning indicators. The grille was also changed; it had two horizontal bars instead of one. The front bumper design was slightly changed, it now has round fog lights compared to the previous rectangle fog lights and in addition to the lower grill there are two horizontal bars instead of one. The rear bumper reflectors were longer and narrower.
Facelift Honda CR-V (US)
On the inside of the car, the EX trim received upgrades which included steering wheel-mounted audio controls and an outside temperature monitor. The stereo system was also XM Satellite Radio ready (USA but not Canada). All CR-V models also had revised rear seat headrests, which had been redesigned to reduce rear view blockage.
Mechanically, the 2005 model was also changed. A major change included a drive-by-wire throttle for all CR-Vs. The all-wheel drive system was improved; it had been tuned to activate faster in low traction situations. US market models were equipped with a five-speed automatic, as opposed to the previous four-speed automatic.
In the United States and Canada, all 2005 and later CR-Vs have ABS, Electronic brake force distribution, front seat-mounted side airbags, and side-curtain airbags with rollover sensors for all occupants. Also, Traction Control and Vehicle Stability Assist were added as standard equipment on all trim levels for increased rollover protection.
In Australia, the MY05 facelift went on sale in late 2004. Base models made do with only dual airbags and ABS as standard equipment, while the Sport came equipped with side airbags for the first time. Curtain airbags were unavailable on any model, until the next generation.
Following the tradition of adding a trim level above the EX during the refresh like the first generation CR-V, Honda added the SE trim level for the 2005 CR-V. The CR-V SE had painted bumpers, body side molding, and spare tire cover. For a more luxurious experience, Honda added a leather interior, leather-wrapped steering wheel, and heated side mirrors and front seats. The SE also included a hard body-colored cover for the spare tire on the back.
Here is a picture of my 2002 Honda CRV Auto Lx RT-AWD
MODS:
-HID: H4 65watts from DDMTuning.com
-225/65/R17 w/07 Civic Si Rims
-8mm spacers
-Brushguard up front
-OEM Visors
-AVS front hood deflector
-ADDCO Rear Sway Bar Upgrade 7/8" Diameter
-Curt Class 3 Hitch
future MOD
Thinking about doing the CCM lift.
Old 04-25-2012, 08:22 AM
youngkipper's Avatar
Default Re: 2002-2006 Honda CRV Performance Thread
has anyone lifted there 2002- 2007 crv? im finding only rear springs available, but did notice that you can buy the element lift kit and the part numbers cross although im worried about the alignment issues....anyone out there that did a lift on thiese years?
Old 05-09-2012, 03:46 PM
norcalem2's Avatar
yes you can buy the Element lift kit and the numbers do match the top hats of the CRV.
The only thing you need to add to that kit is stronger endlinks for your sway bars. and buy front and rear camber kit. But other people have purchase that kit before and worked out fine.
Just keep in mind that that lifting your CRV will wear out other parts faster like bushings and bearings. Also if you go with a taller wider wheel consider upgrading your brakes.
Old 01-24-2013, 11:04 AM
norcalem2's Avatar
has been updated: 1/24/2013
Old 01-28-2013, 11:23 AM
norcalem2's Avatar
Amazon Amazon
thinking about getting these rims and selling my SI rims
225/70/R15 tires
what do you guys think? or should i just keep my SI rims?
Old 01-28-2013, 02:17 PM
biohazardx369's Avatar
Those SI rims look sick on your CR-V! I'd keep them!
bullet style wheels are best left for jeeps IMO.
Old 02-04-2013, 03:47 PM
norcalem2's Avatar
Thanks. I think I am going to keep them.
Not sure what I am going to do next. I am thinking of getting another CRV 5speed manual. I am not sure how much longer my auto tranny going to last. I beat the crap out of it all the time. But I do change my tranny fluid every 10k with the rear diff also.
Old 02-07-2013, 04:31 PM
Ever since picking up this slush-box, I've been wanting a manual to go along with it (with the TSX 6th gear mod.) I know what you mean about the auto tranny, mine has developed a "whir" upon acceleration/cruise at low speeds (0-30mph) so we'll see how long it lasts. I have started doing the ATF 3qt drain every 10k as well.
What kind of MPG do you get with that wheel/tire combination? I'd love to set my V up like that, but I'm getting anywhere from 25-29mpg/tank stock, and don't want to loose the mpg (even though I should be driving my Acura more, which has gotten as high as 38mpg/tank)
SIMMI: I could go without the chameleon paint and those 22's? but sure would love to have those LCA's and brake kit!
Old 02-11-2013, 09:55 AM
norcalem2's Avatar
MPG hasn't change too much. But I have lost a lot of torque. I wouldn't recommend it unless you do a lot of offroad driving. You will have to change your driving style to keep the same MPG as stock. If you don't and you drive very aggresive then your MPG is worst.
If most of your driving is on the high way and streets I would stay with stock recommend size.
You can drain 4qt of tranny oil if you put rams on the back of your car. I usually back up onto ramps on flat ground. Also your rear diff will drain better as well and easier to access.
Old 02-15-2013, 05:01 PM
eg92b16's Avatar
Good info guys !!! I just trade my 99 crv 5spd for a 02 crv 5spd also
Old 02-19-2013, 08:48 AM
norcalem2's Avatar
Thank you! How do you like the 2nd crv compaired to the first gen?
Old 02-19-2013, 09:19 AM
eg92b16's Avatar
Love it better handle more power seats are more comfortable more room in the back,it's a better upgrade i know the 02^ have tranny problems but the 5sped feels right now when am doing 60mph my rpm seat under 3k with the 1gen doing 60mph my rmp seat right pass 3k . Also when you step on the gas u feel it's moving befored i had to wait for the respond of the rmp to come up . For my opinion it's a better upgrade hands down , just like any other regular car jist got to keep up with the maintenance oil , tranny fluid , diff fluid , , also since it come with 4disc break that is a +
Old 11-13-2013, 09:08 PM
crx88ia's Avatar
Bump?
Anyone used the HR springs? Seems easier than bolting on a civic kit but the adjust-ability of coilovers would be nice. Not a thousand dollars nice though.
Old 12-15-2013, 09:49 PM
Punkaddic's Avatar
header is also available from obx, anyone has one ?
http://www.ssaccessories.com/servlet...ER-LONG/Detail
Old 12-16-2013, 03:40 AM
I have been eying this as well since my cat has blown out. I would love to hear any hands-on input.
Old 12-30-2013, 09:33 PM
ninor's Avatar
I have this header, just came in few days ago. For the money it looks pretty good, primaries look kind of on the small side, but looks like nice enough piece with reasonable construction... Again considering the price there is nothing to complain about.
Once I am ready to put it on it will be more telling, most likely will wait until spring though. It is WAY too cold and I just finished putting TSX gears with 6th spd. Needless to say freezing and chilling under the car is not fun part of this hobby.
Since I have some TSX parts kicking around I was contemplating swapping rockers/cams into CRV head and of course next on my mind is engine management.
I didn't have much time to research, but so far not much is turning up.
Do any of you guys have or know anyone that runs Kpro on 2002+ MT CRV? Any links to this info? Any of you know what turbo and SC guys use in theirs for engine management?
I kind of briefly looked at Hondata web site and oddly they don't list 2002 MT CRV as Kpro application, they do list it as ECU 'donor' vehicle to use on other cars. I do notice Element is listed with some sort of adapter harness and they recommend CRV ECU for that application.
This leads me to think that while 02-04 CRV MT ECU will accept Kpro, it actually might not work in CRV, as in run dash and other functions (except engine, which it should run).
Anyway, any info would be appreciated.
Regards,
Nino
Old 02-14-2014, 06:02 PM
Fish Twig
tony_2018's Avatar
Performance wise, since the 05 model is drive by wire would it be possible to swap in a tsx k24a2 and use the dual ecu setup?
Old 08-21-2014, 09:50 AM
eghatch4sale's Avatar
Does any one know for sure what needs to be done to update the front bumper to a 05-06 and taillights ? I'm new to the 2nd gen crvs and have tried searching
Old 10-09-2014, 10:37 PM
norcalem2's Avatar
Just swap heads with k20a, k20a2, or k24a2. Same differents. Use what ever ecu you got the head from.
Old 10-09-2014, 10:43 PM
norcalem2's Avatar
Front end swap update you will need: front bumper, headlamps, hood, and fenders. Also you will need to rewire the headlights and turn signals.
Rear tail lights you will need rewire, purchase the wire sockets, and purchase the 05-06 tail lights.
Old 10-22-2014, 12:16 PM
Brick_CRV's Avatar
Default K20a2 intake on K20a4?
Hi guys,
Posted this before in section K-series but this also might be a good place
Can someone tell me if a K20a2 (Integra) intake manifold + throttle body would fit a K20a4 (CR-V)?
Regards,
P
Old 10-29-2014, 06:33 PM
norcalem2's Avatar
Default Re: K20a2 intake on K20a4?
Originally Posted by Brick_CRV
Hi guys,
Regards,
P
this should work as long as your car is not drive by wire. You will need the intake manifold and throttle body from the RSX/integra. Also you might want to look at the TSX/Euro R accord intake manifold or throttle body.
Old 03-21-2015, 11:55 AM
eg92b16's Avatar
nicee threat
Old 06-25-2015, 08:53 AM
Usmcmadavisdog's Avatar
I just purchased the 3" lift kit and I'm a little nervous myself
Old 10-17-2015, 05:45 AM
2k3crv's Avatar
ssaccessories.com
Yes, I bought one awhile back. The top two stud holes on the header flange have to be filed outwards in order to fit onto the engine head. Also, it hits the front sway bar so you have to install washers under the sway bar bushing mounts to clear it. This header, combined with 2.5" pipe and a 40 series Flowmaster muffler is LOUD as hell. Lol I ended up taking the header back off.
Quick Reply: 2002-2006 Honda CRV Performance Thread
