car wont start after it over heated.
Old 04-02-2012, 02:58 PM
freshCROOKS's Avatar
Default car wont start after it over heated.
so my friend bought a 96 civic hatch the other day. We were driving it back have and it over heated (hour and a half of driving). Pulled Imy the gas station and I checked it out. No coolant what so ever. also found out that the thermostat wasn't working and was closed the whole time. We tried filling the radiator up with water and still no start. It had the cel on. 4 codes. Engine coolant temp sensor, catalytic converter, misfire in cylinder 1 and 3. It cranks but won't start.fuel pump is working. Idk what to check next. I'm kinda new at this and still trying to learn. where to i go from here? What else can I check? What can it possible be? PLEASE HELP!!!
freshCROOKS is offline
Old 04-02-2012, 03:00 PM
dE.fUsEd's Avatar
Default Re: car wont start after it over heated.
Ouch. Check the oil, what color is it?
dE.fUsEd is offline
Old 04-02-2012, 03:21 PM
Silvertune's Avatar
Time for a new motor.
Silvertune is offline
Old 04-02-2012, 05:34 PM
Bradshaw's Avatar
yep check oil. if your coolant is all gone though, i'd say your motor is too. thats got blown headgasket written all over it
Bradshaw is offline
Old 04-02-2012, 05:55 PM
Cmoya07's Avatar
thats why i never use water because it just boils out in the summer and freezes and cracks your block in the winter....always use anti-freeze
Cmoya07 is offline
Old 04-03-2012, 09:46 PM
should I replace the head gasket or just get another motor.
Old 04-03-2012, 09:49 PM
Oil looks fine
Old 04-03-2012, 10:06 PM
furious94ls's Avatar
Most likely it's done.
furious94ls is offline
Old 04-03-2012, 10:46 PM
jbpnoman's Avatar
The motor isn't scrap yet. Take the head off. Look for cracked cylinder walls. It's time to find out just how bad you guys screwed up that motor.
jbpnoman is offline
Old 04-03-2012, 10:55 PM
Voodoo7's Avatar
drain the oil, if its milky than you have blown the head gasket. Other than that the only other symptoms of those codes would be bad plugs/spark, or a clogged cat. But I would go ahead and assume you will have chocolate milk when you drain the oil. Like stated above pull the head and see what kind of damage you have done to it. Most likely it will be cheaper to just replace the motor.
Voodoo7 is offline
Old 04-04-2012, 03:13 AM
Seagull Management
94EG8's Avatar
Overheated aluminum block for an hour and a half is absolutely scrap. You can almost definitely get it to run again, but it will take a oil at a ridiculous rate.
94EG8 is offline
Old 04-04-2012, 05:01 AM
jbpnoman's Avatar
What? The way I read the OP was that it was driven for an hour and a half, which the OP thinks is what caused the overheating. If he/his friend actually drove the car for an hour and a half with it overheating, they need to sell it to the junk yard, and use what little they get for it to buy a bicycle. What kind of moron drives a car for an hour and a half with it overheating?
jbpnoman is offline
Old 04-04-2012, 06:58 AM
Seagull Management
94EG8's Avatar
Does this answer your question?
It wasn't mine, I just got hired to sort it out one time. It was driven overheated about that long. Temp gauge didn't work, guy didn't notice it was overheated till he saw smoke coming from under the hood. Kept driving because he was scared it wouldn't start if he shut it off.
94EG8 is offline
Old 04-04-2012, 08:00 AM
dE.fUsEd's Avatar
Originally Posted by freshCROOKS
Oil looks fine
I would buy a compression tester and then a leak down tester.
Unhook the CPU fuse under the dash, and do a compression test.
If bad compression, proceed to do a leak down.
They are both VERY easy to do.
dE.fUsEd is offline
Old 04-04-2012, 08:01 AM
dE.fUsEd's Avatar
Holy crap.
dE.fUsEd is offline
Old 04-04-2012, 09:14 AM
The temp gauge wasn't working so Idk how long we been driving it while over heating. About an hour and a half later, it started smoking and died out. Don't have to to check it today but most likely this weekend.
Old 04-04-2012, 01:39 PM
jbpnoman's Avatar
Oh.
My.
God.
Go get a new motor out of a junk yard. You're SOL.
jbpnoman is offline
Old 10-28-2012, 10:07 PM
Jiyusan's Avatar
Holy Smokes!
I wont use water anymore.
Jiyusan is offline
Old 10-29-2012, 08:03 AM
Fnix's Avatar
Is there a way to have a block tested and see if it is still good after overheating?
Fnix is offline
Old 10-29-2012, 11:12 AM
HondaMyWayOfLyf's Avatar
damn thats shitty, yep time for a new engine IMO i would NEVER buy a car with the heat gauge not working thats just sketched out
HondaMyWayOfLyf is offline
Old 08-22-2017, 04:04 PM
Terry Hernandez's Avatar
Girl friend a has a honda civic202 and it run hot I changed the head gasket. It turns over but Wil not start what do y'all think timing or value s help
Terry Hernandez is offline
Old 08-22-2017, 04:35 PM
mk378's Avatar
You're in the wrong forum for a "202".
A general rule is that driving overheated until the car will go no more means that you will need a new engine. There is likely no compression due to damage to the rings.
mk378 is offline
turbohb21
09-24-2007 11:36 PM
fms1day
38
07-05-2006 02:44 PM
VRD^don
12
06-03-2005 09:43 AM
J-g-D-s-M-r
04-27-2005 12:36 AM
tdo
02-14-2005 04:07 AM
Quick Reply: car wont start after it over heated.
