Go Back   Honda-Tech > Honda and Acura Technical Forums > All Motor/ Naturally Aspirated
Old 03-31-2012, 10:52 PM   #1
F20Cdriver
F20Cdriver's Avatar
Icon2 Rebuilt Motor Won't Start...
So first I want to say, thanks for reading and for any help with my problem.
Car is a stock civic D16Y8 with all stock internals. I tried starting the car today for the first time since the rebuild. the engine turns over and makes a muffled poping sound and doesnt start. the muffled poping sound happens once or twice, and some times not at all, during each start attempt.
Also, on a different note, my clutch pedal seems too soft for a brand new flywheel, clutch disc, pressure plate, throughout bearing, and pilot bearing. any common problems i should know about? Tranny is stock hydraulic and clutch components are stock replacements.
thanks again
F20Cdriver is offline   Reply With Quote
Old 04-01-2012, 10:33 AM   #2
HulkSmash
HulkSmash's Avatar
Default Re: Rebuilt Motor Won't Start...
check for spark and fuel.
HulkSmash is offline   Reply With Quote
Old 04-01-2012, 01:10 PM   #3
OneBadTurboCRV
OneBadTurboCRV's Avatar
It sounds like either your mechanical or ignition timing is too far off.
Also, you never said what vehicle/engine or type of transmission you have (hydro/cable) so its hard to help you.
--- '13 Civic Si --- '98 CRV EX --- '95 Civic LX --- '91 Civic DX ---
OneBadTurboCRV is offline   Reply With Quote
Old 04-01-2012, 02:10 PM   #4
F20Cdriver
F20Cdriver's Avatar
"It sounds like either your mechanical or ignition timing is too far off.
Also, you never said what vehicle/engine or type of transmission you have (hydro/cable) so its hard to help you"
-okay so i should check my ignition timing. i know for sure that my mechanical timing is precise because i did and re-did it before installing.
"check for spark and fuel."
-could you give me a quick explanation on how to do that? thanks
Old 04-01-2012, 02:15 PM   #5
DDTECH
1992 Honda Civic
DDTECH's Avatar
customcams
Send a message via AIM to DDTECH
Pull the rail, see if the injectors shoot.
Pull a plug, and a spark plug, and put it close to a ground, see if it sparks.
Generally speaking never, is right, sounds like either a mech timing issue, or your plugs are in the wrong order.
DDTECH(DDTECHCAMS.com) - Round2Motorsports - LUMP Racing - Sheepey INC - Phearable.net - SpeedTrapp Consulting
Shelf Profiles and Custom Profile camshafts for Imports and Domestics
DDTECH is offline   Reply With Quote
Old 04-01-2012, 02:16 PM   #6
negusjuda
negusjuda's Avatar
make sure your plug wires are on right and as far as the clutch try bleeding the clutch
REJECT☆SQUAD#21
negusjuda is offline   Reply With Quote
Old 04-01-2012, 02:17 PM   #7
negusjuda
negusjuda's Avatar
exactly as allmotor said sounds like you may have the plug order wrong
REJECT☆SQUAD#21
Old 04-01-2012, 02:28 PM   #8
F20Cdriver
F20Cdriver's Avatar
on the to do list, thanks
okay sounds like a great start. i checked my starter and it was pretty hot. do you think thats a result of bad timing or could the starter just be bad?
thanks
Old 04-01-2012, 03:11 PM   #9
F20Cdriver
F20Cdriver's Avatar
YES...finally started the car!
thanks for the help negusjuda and all motor.
i checked for spark and that was the problem, but i have p0304(cyl #4 misfire), p0302(cyl #2 misfire), p0300(random cyl misfire), and p1399(any cyl misfire). it has to be a timing issue, right?
Old 04-01-2012, 04:04 PM   #10
DDTECH
1992 Honda Civic
DDTECH's Avatar
customcams
Timing issue, or something of the plugs.
Maybe gap too tight? Wrong plugs? Timing off a hair causing an advanced spark or retarded spark.. just alot to check.
STart with your timing - its a sohc, shouldn't be hard to have the gear with the up arrow up and the tdc mark on the crank lined up.
I would think check to make sure everything is tight and gapped correctly.
Old 04-01-2012, 04:33 PM   #11
F20Cdriver
F20Cdriver's Avatar
restarted the engine with new plugs that i gapped before installing, but same result.
how do i check the timing exactly? i did a valve adjustment and made sure that the belt was installed according to honda manual.
Old 04-01-2012, 04:37 PM   #12
DDTECH
1992 Honda Civic
DDTECH's Avatar
customcams
Valve lash adjustment, check it, when the engine is COLD.
There's a writeup on here on a d16 valvelash adjustments.
Timing would be simple, there's also a writing up on checking / doing timing. Alittle research will take you along way, if you get stumped report back. Can't do all the leg work for you
Old 04-01-2012, 05:21 PM   #13
F20Cdriver
F20Cdriver's Avatar
haha, yeah i got lazy there for a second. thanks for the help!
Old 04-02-2012, 01:32 PM   #14
F20Cdriver
F20Cdriver's Avatar
it was mechanical timing, thanks for the help (d16y8 w/stock everything...for now)
thanks for the advice, turns out i needed to re-do my valve adjustment. for what ever reason when i did the valve adjustment on the engine stand it needed another valve adjustment once it was sitting pretty in the engine bay.
now i have white smoke comming from under the exhaust manifold right where the head and block mate. i dont understand because the head gasket was changed and head bolts where bolted to spec(sequentially 1,2,3,4 final at 49 ftlbs)
Old 04-02-2012, 01:37 PM   #15
DDTECH
1992 Honda Civic
DDTECH's Avatar
customcams
now i have white smoke comming from under the exhaust manifold right where the head and block mate. i dont understand because the head gasket was changed and head studs where bolted to spec.
Does the smoke eventually go away?? What about reving??
Old 04-02-2012, 02:06 PM   #16
F20Cdriver
F20Cdriver's Avatar
The smoke seems to be comming out from the exhaust side and not the intake side, is it sensible to assume that it might just be an old exhaust manifold gasket and not a head/block issue?
Old 04-02-2012, 02:09 PM   #17
F20Cdriver
F20Cdriver's Avatar
it doesnt go away, but i havent left it on for an extended period of time either. i havent reved it passed 4k, should i try reving it and see if smoke amount is correlated with reving?
Old 04-02-2012, 03:56 PM   #18
DDTECH
1992 Honda Civic
DDTECH's Avatar
customcams
Might be condensation, not sure though..
While the car is cold, take off the rad cap, have someone sit in the car and start it, and rev it up, if the rad bubbles, HG leak around the water jacket, if not, then there's possible a leak somewhere hitting something like your exhaust manifold or it is, infact condensation.
remember, you've been touching the motor alot checking things and stuff..
Old 04-02-2012, 04:16 PM   #19
F20Cdriver
F20Cdriver's Avatar
thanks for all of your help man, really, you've steered me in the right direction and saved me a lot of time and effort. i fixed the problem(knock on wood) and everything seems to be running smoothly. i need to do another valve adjustment because the engine shakes a little. other than that, i can finally drive my car after 7 months of wrenching, researching, stressing, bus riding, saving money, and spending money-the journey is completed...now on to the mods
thank you to everyone else who responded with very helpfull information, peace
Old 04-02-2012, 04:25 PM   #20
DDTECH
1992 Honda Civic
DDTECH's Avatar
customcams
IF you need anymore help, feel free to pm or make another post.
Old 04-05-2012, 09:36 PM   #21
F20Cdriver
F20Cdriver's Avatar
will do, thanks again.
car, d16y8, engine, honda, motor, overalled, rebuilt, s2000, slow, start, turns, wont
