Tips for removing the crankshaft pulley bolt?
Old 04-01-2012, 09:02 AM
  #26
Master Detailer
98civdx's Avatar
Default Re: Tips for removing the crankshaft pulley bolt?
I agree, Honda's aren't that bad to work on.
Old 04-01-2012, 09:32 AM
  #27
nealnanoHX's Avatar
Use a good 1/2 inch impact gun like a Macto or Snap On with 150psi of air behind it and a 19mm impact socket. Crank bolt comes right off.
Old 04-01-2012, 09:35 AM
  #28
nealnanoHX's Avatar
Originally Posted by dlstech
I started changing my timing belt but got stuck at the crankshaft pulley bolt. Neither of my impact guns could get it off. I tried turning the compressor pressure up to 125 psi and still nothing. So I took off the starter and put a big screwdriver in the flywheel teeth. I still couldn't get it to budge with a breaker bar so I put a 4 foot pipe over it and tried again. My 1/2" extension snapped. That extension and my impact gun have gotten a lot of tough bolts off and haven't failed me ever. So I know it's not just my tools. I don't have cheap tools either.
What else can I do? I was gonna stop by a few shops to see if they have a stronger gun but most of them were already closed so I'm stuck for now.
Should be called Snap-Off instead lol
LMFAO I call Snap On Snap Off.
Old 04-01-2012, 09:38 AM
  #29
nealnanoHX's Avatar
It's 17mm. And I'll rent that tool and let you guys know how it goes.
Wrong D,B,H,J,K and F series all have been a 19mm IME.
Old 04-01-2012, 10:04 AM
  #30
Master Detailer
98civdx's Avatar
D series 17mm.
Old 04-01-2012, 10:27 AM
  #31
Marvin1985's Avatar
D series is 17mm. Please if your not sure don't comment on it. Your just misleading people.
Old 04-01-2012, 11:07 AM
  #32
EK9
Dc4LsTeG's Avatar
Originally Posted by 98civdx
D series 17mm.
X3
Old 04-01-2012, 02:02 PM
  #33
v8killaz's Avatar
hondas are like lego's. i absolutely love working on pre-00 hondas. when my chevy has a problem man i just want to hang myself. many times i just dont bother fixing it and deal with the problem. everything is a pain and expensive. hondas are easy and dirt cheap
Old 05-20-2021, 11:01 PM
  #34
Oh look, I can change this
deschlong's Avatar
Thanks for this. Had a stubborn bolt on a 2000 Civic with T belt that is triple its intended lifetime. Used the breaker bar and jackstand method and it made such a big crack that I thought I broke a tool first before checking the bolt.
I've done 4-5 of these before with my own air tools and to have one that didn't budge with them was a surprise.
DaX
Old 05-21-2021, 04:37 AM
  #35
punk0mi's Avatar
A harmonic impact socket and a decent 1/2 impact will do it usually.
Amazon Amazon
A harmonic impact socket has more mass than a standard impact socket...this will help loosen it by using that mass in rotational force.
Old 04-30-2022, 11:59 AM
  #36
deschlong's Avatar
https://www.amazon.com/Lisle-77080-H...s%2C172&sr=8-3
Not if you're this guy! https://honda-tech.com/forums/honda-.../#post52570009
jeffreysumlin
03-07-2006 07:39 AM
FairlightRacing
02-22-2005 06:26 AM
slwburn
04-03-2004 04:15 PM
Ri5e
03-16-2002 12:19 AM
jas_honda_uk
03-14-2002 04:07 PM
Quick Reply: Tips for removing the crankshaft pulley bolt?
