Old 03-30-2012, 04:55 PM   #1
dlstech
Default Tips for removing the crankshaft pulley bolt?
I started changing my timing belt but got stuck at the crankshaft pulley bolt. Neither of my impact guns could get it off. I tried turning the compressor pressure up to 125 psi and still nothing. So I took off the starter and put a big screwdriver in the flywheel teeth. I still couldn't get it to budge with a breaker bar so I put a 4 foot pipe over it and tried again. My 1/2" extension snapped. That extension and my impact gun have gotten a lot of tough bolts off and haven't failed me ever. So I know it's not just my tools. I don't have cheap tools either.
What else can I do? I was gonna stop by a few shops to see if they have a stronger gun but most of them were already closed so I'm stuck for now.
Should be called Snap-Off instead lol
dlstech is offline   Reply With Quote
Old 03-30-2012, 05:11 PM   #2
98civdx
Master Detailer
98civdx's Avatar
Default Re: Tips for removing the crankshaft pulley bolt?
A impact with 1200lb's of brake away torque....
Or a breaker bar, with a big *** cheater pipe.
Use a jack stand to set the extentensions on to keep them flat.
These bolts really suck. Has the car already been taken apart?
RIP Michael Young. 3-26-1991 9-2-2013
98civdx is offline   Reply With Quote
Old 03-30-2012, 05:30 PM   #3
dlstech
As you can see, the breaker bar with big *** cheater pipe snapped my extension lol.
It was taken apart but I put it all back together because I need a car to drive.
I will go to a few shops and see if they have a better gun. Mine is 600 lb max for reverse and that didn't do a thing.
I just want to know what else you guys do to get these off. I've always just used my impact gun without a problem
Old 03-30-2012, 05:38 PM   #4
Arthas
2004 Honda S2000
My Garage
Arthas's Avatar
IvenVargas
Send a message via AIM to Arthas
Rent this tool. Youll NEED this tool unless you have the world strongest compressor ever.
You put in inside of the crank, and you put a half inch ratchet on it to hold it. Then with another half inch breaker bar, you break the bolt loose.
When I was stuck on that bolt I tried everything from drowning it PB blaster, putting a torch to it, 3 different compressors and nothing. Once I got that tool from Pep Boys, I had it off in under 2 minutes.
2003 Honda S2000 Sebring silver (RIP)
2004 Honda S2000 Nighthawk black pearl (Weekend Warrior)
2003 Hyundai Accent (Daily Driver)
Arthas is offline   Reply With Quote
Old 03-30-2012, 05:49 PM   #5
dlstech
Ok I was looking at that picture for like 5 minutes and can't figure out where the 1/2 ratchet would go...
Old 03-30-2012, 05:54 PM   #6
chewyv
pm4nudes
chewyv's Avatar
NOT A TARGET
LOL. They actually rent them at oreilly. I found that out too late when I bought mine.
chewyv is offline   Reply With Quote
Old 03-30-2012, 06:01 PM   #7
98civdx
Master Detailer
98civdx's Avatar
That tool are a must have for this job, NO MATTER what. You have to have one.
I just got mad at my car and to a shop and had them break it free, and then tighen enough to get me home....
Old 03-30-2012, 09:28 PM   #8
beecee18
beecee18's Avatar
A decent or better impact gun,
Good 19mm impact socket,
A decent or better air compressor,
Air hose,
120-140psi,
Some confidence,
And the trade off is the bolt in your hand.
beecee18 is offline   Reply With Quote
Old 03-30-2012, 10:01 PM   #9
dlstech
It's 17mm. And I'll rent that tool and let you guys know how it goes.
Old 03-30-2012, 10:05 PM   #10
gwarfare
gwarfare's Avatar
Torch the bolt, when its still hot hit it with the impact and it will spin off easy,try it before u knock it a simple torch will work,trick that my boy showed me.
gwarfare is offline   Reply With Quote
Old 03-30-2012, 10:08 PM   #11
gwarfare
gwarfare's Avatar
It when it works and will work,thank me later,make sure no plastic is around like ur fender cover or any wires.
Old 03-30-2012, 10:26 PM   #12
JDM_teh_WIN!!
JDM_teh_WIN!!'s Avatar
I wouldn't recomend torching that bolt as the damper has rubber in it and the oil seal can easily be distorted as well.
Rollin' teh daily sleeper a.k.a "Project Mayhem"
JDM_teh_WIN!! is offline   Reply With Quote
Old 03-30-2012, 11:46 PM   #13
v8killaz
v8killaz's Avatar
my cheapass harbor freight impact has taken about 100 off. id warm it up slightly. not alot since the pulley has rubber in it than cool it quickly. sometimes it works for me.
if thats doesnt work what i do is hold the flywheel and use a breaker bar. that snapon extension is cheap if it broke i use cheap tools and they wont break. unles its not rated for impacts
99 si for sale or trade
http://hondamarketplace.com/showthread.php?t=2746271
v8killaz is offline   Reply With Quote
Old 03-30-2012, 11:53 PM   #14
TOO MUCH TORQUE
TOO MUCH TORQUE's Avatar
use the "starter" method. youtube it.
TOO MUCH TORQUE is offline   Reply With Quote
Old 03-31-2012, 08:20 AM   #15
dlstech
Can't use the starter method because the engine and bolt spin in the same direction.
So what seal can get damaged if it's heated up too much? The front main? Because I have a new one anyways.
Old 03-31-2012, 09:11 AM   #16
Arthas
2004 Honda S2000
My Garage
Arthas's Avatar
IvenVargas
It goes in the end. Where it looks like a circle, a 1/2" ratchet makes itself at home.
QUOTED FOR TRUTH.
I torched for about an hour and nothing.
OP just rent this tool. Itll make your life so much easier.
Old 03-31-2012, 09:52 AM   #17
redm3turbo
redm3turbo's Avatar
Tool is 20 bucks on amazon
http://www.youtube.com/watch?v=RE-pzP8g_x4
Cheaper then breaking anything made by snap on
redm3turbo is offline   Reply With Quote
Old 03-31-2012, 12:24 PM   #18
Marvin1985
Marvin1985's Avatar
iTrader Rating: (4)
Marvin Alvarado Tigris4149
That tool is $120 at Honda. I tried everything to get mine out. I was screwed cuz engine wasn't in car! Had to take mine to a shop and it came out like butter then found out my bro had the tool.
Originally Posted by rycrkt View Post
I did try! I'm herbally challenged...
Marvin1985 is offline   Reply With Quote
Old 03-31-2012, 04:41 PM   #19
redm3turbo
redm3turbo's Avatar
http://www.amazon.com/Honda-Acura-Cr.../dp/B004QJOVBK
amazon $26
Old 03-31-2012, 04:57 PM   #20
EK9Rsc
impact is how i did mine
EK9Rsc is offline   Reply With Quote
Old 03-31-2012, 05:04 PM   #21
Dc4LsTeG
EK9
Dc4LsTeG's Avatar
iTrader Rating: (7)
You can do it with the vice grip style chain wrench to that's what I've always used
98 Civic Type R/Boosted B18C5
Dc4LsTeG is offline   Reply With Quote
Old 03-31-2012, 06:23 PM   #22
v8killaz
v8killaz's Avatar
holy **** someone used a extension the correct way
Old 03-31-2012, 08:58 PM   #23
Arthas
2004 Honda S2000
My Garage
Arthas's Avatar
IvenVargas
Honda, y u make dis so difficult?
Old 03-31-2012, 10:45 PM   #24
98civdx
Master Detailer
98civdx's Avatar
Becuase the crank pulleys are a "slip-fit"
On some/most cars you need a pulley puller to get the crank pulleys off, and the bolts come off really easily.
It's the way our cars were designed.
Old 04-01-2012, 04:31 AM   #25
redm3turbo
redm3turbo's Avatar
I used to think it was hard to work on hondas
Then my mom got a chevy malibu. This was about 10 years ago, when they had notorious IM leaks. To change an IM gasket in a gm, it literally is easier to just pull the engine out the car.
Took me damn near 2 full days to change the gasket, and I had a cousin helping that was a ASE. We had to take so many things apart, just to get to the IM gasket.
Then 2 months later, it was all over again because the timing chain needed changing.
The next day, she traded it in on an accord. Never again will I wrench on a gm.
I agree that the crank bolt pulley is a bitch *til you have the tool/good air tools* however you can still bring it to a shop, pay 5, have them back it off for you, and go home and change your timing belt in a good 3 hours. Then have another 6 years of driving headache free. On american cars, you are lucky to get 6 years driving without changing the whole motor. In hondas you swap the motors because you desire more power, then some kid buys your old motor, beats on it for 5 years, and it still runs. Not so much on the americans. My buddy has a ford lighting and we always joke that the 5.4 engine is a "wear item" since he's on his 4th motor in 3 years , lol.
1991, bolt, broken, chain, civic, crankshaft, honda, pulley, remove, removing, s2000, sale, screw, stuck, timing, tools
