Old 03-29-2012, 09:46 PM   #1
invader_zim
1991 Honda Accord
invader_zim's Avatar
TableSaltZombie
Send a message via AIM to invader_zim
Default 91 Accord Transmission Problem
I start the car and put it in reverse and its fine, but when I put it in drive and start to move it starts to run fine for a couple inches then starts slipping and the "s" light blinks until i turn the car off again. I was hoping it might just be the solenoid or the trans computer but something tells me the trans is done. Any input is appreciated
invader_zim is offline   Reply With Quote
Old 03-29-2012, 10:23 PM   #2
MAD_MIKE
MAD_MIKE's Avatar
Default Re: 91 Accord Transmission Problem
Pull out blue connector find out what code is. Click on H4A link in my sig.
MAD_MIKE is offline   Reply With Quote
Old 03-29-2012, 10:50 PM   #3
invader_zim
1991 Honda Accord
TableSaltZombie
Thank you, I checked the codes and got code 1, 2 & 8. Im guessing that my shift solenoid needs cleaning? Going to go clean it and report back
Old 03-29-2012, 11:07 PM   #4
MAD_MIKE
MAD_MIKE's Avatar
Keep in mind, if you looked over that link, that some 90-91 TCUs had bad capacitors/resistors. Before you pull solenoids out, carefully remove the TCU and inspect its capacitors and resistors.
Old 03-30-2012, 10:05 AM   #5
invader_zim
1991 Honda Accord
TableSaltZombie
took out the tcu and inspected it, everything looks fine as far as that goes. going to be taking off the shift solenoid and cleaning it in a few minutes
Old 03-30-2012, 03:36 PM   #6
invader_zim
1991 Honda Accord
TableSaltZombie
Both solenoid assemblies have been cleaned and the only code now is code 8
Old 03-31-2012, 12:51 AM   #7
MAD_MIKE
MAD_MIKE's Avatar
Did you check the resistance values of the solenoids coils? Check the connectors to them and your ground, should be on the front right corner on a metal bracket near the AT dipstick tube. Follow it directly from the negative battery cable.
Old 03-31-2012, 06:31 PM   #8
invader_zim
1991 Honda Accord
TableSaltZombie
Problem solved, it ended up being the sift solenoid. Replaced it andif shifts smoother than it did before. Thank you for your time and help!
91, accord, clean, code, codes, honda, problem, problems, pull, skipping, slipping, solenoid, trans, transmission
