Flush manual transmission fluid?
Old 03-26-2012, 03:45 PM
dlstech's Avatar
Default Flush manual transmission fluid?
I'm in the middle of doing my manual transmission fluid change. I don't know when the last time it was changed and it came out really dark. I was wondering if I should fill it with motor oil and drive around for a few miles and then drain and fill with the Honda manual transmission fluid?
Would there be any gain or should I just fill it with Honda fluid now and leave it at that?
Old 03-26-2012, 06:24 PM
jbpnoman's Avatar
Default Re: Flush manual transmission fluid?
Just fill it with Honda MTF. Drive on fresh MTF for a few thousand, then check the color again.
Old 03-26-2012, 07:38 PM
Oh look, I can change this
deschlong's Avatar
This. Though, depending on the year, you don't need Honda MTF and regular motor oil is called for by the service manual (for 92-95). Definitely do NOT put anything else in there to try to "wash" it out. Just empty and fill with oil, and repeat if desired.
imadigitalgod
187
04-23-2016 07:08 AM
Heat
01-13-2015 11:35 AM
Walter640
Honda CR-V & Element
02-02-2012 03:42 AM
Red Ride
15
04-16-2005 09:00 AM
Ignitecivic
11-20-2001 06:00 PM
Quick Reply: Flush manual transmission fluid?
