Need help identifying this part.
Old 03-24-2012, 08:43 PM
CRX Si69's Avatar
Default Need help identifying this part.
I was told that it is the IACV, but I am not sure as no manuals I have looked at say what it is, and no parts stores knew what it was..
It's an 1989 Honda Accord, 5 speed, A20A1, 2bbl carb.
I would appreciate it if someone would help me out with this.
Old 03-25-2012, 07:57 AM
CRX Si69's Avatar
Default Re: Need help identifying this part.
No one knows what it is? I really need to get it fixed. :X
Old 03-25-2012, 11:18 AM
GhostAccord's Avatar
That looks to be part of the carburetors air vent cut off diaphragm/carb thermovalve.
If you are looking for that specific part for an 89, it is labelled as the SHED diaphragm set and it is Honda part number 16044-PH4-662.
Didn't you have a picture of the actual part up earlier? If you did can you post that back up?
Old 03-25-2012, 12:18 PM
CRX Si69's Avatar
Thanks so much for your reply.
Here is the picture of it on the car, with the diaphragm cover off.
Attachment 536802
Old 03-25-2012, 03:22 PM
OK , I just wanted to make sure that you weren't looking at the other side of the carb, the choke assembly. That item is the air vent cut off diaphragm & carb thermovalve. The AVCO diaphragm is the top part and the CT valve is the bottom portion.
Old 03-25-2012, 04:23 PM
CRX Si69's Avatar
Alright, thank you so much for the help.
Old 03-25-2012, 04:43 PM
You're welcome
Old 03-26-2012, 12:50 PM
jdmcertified909's Avatar
You're welcome
right on ghostaccord before i scrolled down to see your answer. my mind was telling me thermo valve or some sort of air control valve
Old 12-24-2012, 04:33 AM
Radddy49's Avatar
looking for Part#9 in the diagram. What site did this come from? Need urgently Thanks
Old 12-24-2012, 01:17 PM
jdowen2's Avatar
009 16021-PE0-702 DIAPHRAGM SET, PUMP , $27.95 Each Manchester Motorsports
Old 12-26-2012, 07:37 AM
Lost Again's Avatar
What issue are you having?
acmatienzo
02-09-2019 10:48 PM
stock99si
02-17-2008 03:26 PM
BMP_GTI
10-01-2007 03:15 PM
Quick Reply: Need help identifying this part.
