> Tech/Misc
Old 03-22-2012, 06:55 PM   #1
Si818
Stahtic
Send a message via MSN to Si818
Default Failed SMOG. Too high NO and HC??
I just took my car to the smog shop today and I failed the
-NO (PPM) 15mph Mine read:1952 and max is 487 @25mph
-NO (PPM) 25mph READ: 1811 max: 774 @ 25mph
-HC (PPM) 15mph read: 116 max: 66
-HC (PPM) 25mph read: 27 max: 49
Could anyone please help me figure out what's wrong? Or why they measured like this.
my car is 1999 honda civic si
b16a from japan
5 speed
110,000 miles
Si818 is offline   Reply With Quote
Old 03-23-2012, 01:38 PM   #2
TunerN00b
TunerN00b's Avatar
Default Re: Failed SMOG. Too high NO and HC??
Put a working cat on it if it doesn't have one.
If the car has an EGR, clean/replace it. Also check timing and AFR. Running lean increases combustion temp. High combustion temps produce NOx pollution.
TunerN00b is offline   Reply With Quote
Old 03-23-2012, 03:12 PM   #3
Si818
Stahtic
What's an AFR bro? I'll be checking the EGR valve this weekend and timing. Thanks
Old 03-23-2012, 04:03 PM   #4
TunerN00b
TunerN00b's Avatar
air fuel ratio
Old 03-23-2012, 06:35 PM   #5
Si818
Stahtic
For sure man, thanks for the help.
Old 03-23-2012, 08:25 PM   #6
hybridmiklo
hybridmiklo's Avatar
this car does not have an egr. From the looks of those numbers you might need a cat. Post up the other readings such as the o2,co and co2 so I can get a better idea of what might be needed.
hybridmiklo is offline   Reply With Quote
Old 06-05-2012, 11:53 AM   #7
piggydog
piggydog's Avatar
Send a message via AIM to piggydog
hey guys, hope I'm not thread jacking but I'm running into something similar here are my numbers
1992 Honda Prelude 2.3si
Luckily I saved my test from two years ago
Test from 06/2010 - only thing changed after the test was on 11/2011 the distributor, and a few screws on my gas tank (also had a stock filter on in 2010, 2012 I have KN reusable cone filter)
2010 test - pass
http://i1131.photobucket.com/albums/...0smogtest2.jpg
2012 test - failed
http://i1131.photobucket.com/albums/...2smogtest2.jpg
My 2012 results are so high compared to my 2010 tests. Any ideas, the guy says my timing looks off. Do I need to advance the timing on my car? Would that only fix one of those? Should I run any fuel cleaner or seafoam in the tank, suck some seafoam through the brake booster? Thanks for advice.
piggydog is offline   Reply With Quote
accord, car, cat, changing, fail, failed, hc, hcppm, high, hight, hond, honda, ppm, smog, vehicle
