97 civic dies after starting and running a couple minutes
Old 03-15-2012, 06:08 AM
Joshua Howard's Avatar
Default 97 civic dies after starting and running a couple minutes
I have a 97 civic with a d16y8 and its starts fine and runs fine for about ten minutes. After it has been running the rpms drop the car sputters and dies. While the rpm are dropping it will not respond to the gas or clutch pedal being pressed.
If I wait about 5 min and start it again sometimes it will start and drive sometimes it will repeat the previous process and I will have to wait ten minutes. I bought this car in September (it did it twice) and it has done it twice this week.. It has not had the issue at all over the winter but now the weather is warming up (60's - 70's) and it is starting to do it again.
I have read through the boards and I am thinking maybe main relay but honestly I have no idea.
Old 03-15-2012, 07:04 AM
motegicivic's Avatar
Default Re: 97 civic dies after starting and running a couple minutes
Rare for this generation to have main relay issues.
Any CEL's?
I would test the coil and then ICM.
Old 03-15-2012, 07:27 AM
I had an issue over the winter one time where the car wouldn't start but had power when the key was turned to on. When o yried to crank it, it wouldn't turn over. I tried jiggling the key as I started it and it fired up. Are you thinking maybe it is the ignition?
Old 03-15-2012, 07:30 AM
Automatic transmission cel's (ppl that had it before me took the ecu out and put that in). I have a new ecu coming tomorrow. I'm going to check the solders on the main relay just to make sure its good.
Old 03-16-2012, 03:53 PM
MikesEJ1's Avatar
try fuel pump
Old 03-20-2012, 05:15 AM
Update* changed out the fuel filter over the weekend, still having an issue. Like what was stated above I think I have a weak fuel pump, I will try that tonight and update... I love hondas.
Old 03-20-2012, 06:00 AM
delsoltech's Avatar
Yeah, fuel pump came to my mind first. Let us know
Old 03-24-2012, 04:50 PM
bigpunn421's Avatar
mine does this same thing but only once its warm. if its cold it doesnt surge/sputter
raidacaipo
08-27-2014 02:20 PM
sniper_king
08-26-2013 09:42 AM
NemesisVette
49
01-03-2013 12:37 PM
spence19
07-23-2006 02:45 PM
FLCivic
03-27-2005 07:37 PM
Quick Reply: 97 civic dies after starting and running a couple minutes
