Old 03-13-2012, 06:18 PM   #1
RDAYA0
RDAYA0's Avatar
Default 2000 acura integra power door lock problem
considering buying this car with 200,000 canadian km. seller said power door lock switch was working a couple days ago but suddenly stopped. we can still hear it try to lock the doors but won't work. we can only lock and unlock with the key outside. could it be a fuse?
RDAYA0 is offline   Reply With Quote
Old 03-13-2012, 08:11 PM   #2
mark@silbernage
Default Re: 2000 acura integra power door lock problem
If you can hear it trying, the circuitry is working.
It's likely needing lubrication, but I've seen the rods incorrectly installed (so they bind) too.
If everything is correctly assembled and lube is OK, then the solenoid may be weak.
Mark
mark@silbernage is offline   Reply With Quote
Old 03-14-2012, 05:49 AM   #3
RDAYA0
RDAYA0's Avatar
solenoid or actuators? located in the doors right?
Old 03-14-2012, 06:07 AM   #4
fcm
Old Fart
fcm's Avatar
If the power door locks do not work on both/all doors then the problem is unlikely the actuators, if it is only a problem on one door then it most likely is the actuator, and yes it is in the door.
#3/26...
http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal 94
RIP Zack 2001-2013, my best friend.
fcm is offline   Reply With Quote
Old 03-14-2012, 02:40 PM   #5
RDAYA0
RDAYA0's Avatar
so the car is actually a special edition, it does not have power locks. the driver switch is for the hatch unlock/lock. the seller said that it probably came with a remote that locks/unlocks the doors but he does not have it. you guys think this would be a oem remote or an aftermarket one? because theres looks to be an antenna for an alarm near the rear view mirror.
Old 03-14-2012, 03:19 PM   #6
fcm
Old Fart
fcm's Avatar
Pretty sure the SE came with power door locks, an SE is just a GS-R without the engine and transmission, if not, actuators may have been added, your going to have to pull a door panel to know for sure.
You said you could hear something in the door, or is it the hatch that is popping? 94
Old 03-14-2012, 03:55 PM   #7
RDAYA0
RDAYA0's Avatar
the hatch is popping, it's a canadian se. no sunroof either. under the lock switch it says "hatch". hatch locks/unlocks perfectly
Old 03-14-2012, 05:24 PM   #8
raverx3m
raverx3m's Avatar
alot of times door lock mechanism gets dry and seizes up.
i almost snapped my dor handle when i first bought the car
after a quick lube with white lithium grease can i could open it with one finger.
try to move the levers by hand if theres alot of resistance then they are dry and you should not try to use the power door locks untill you get it lubed since it will burn out your motors.
200whp/137tq, GSR pr3 pistons 81.5mm, supertech valves,milled .015
BC3+ cams,RDXinj,PrfrmrX 70mmTB,SRI with vstack tb and im portmatched
Tri-y rep. hdr 2.5 xhst vibrant mfflr, neptune RTP,205/50/16 tire
raverx3m is offline   Reply With Quote
Old 03-14-2012, 10:01 PM   #9
fcm
Old Fart
fcm's Avatar
Your still going to have to pull a door panel to see if aftermarket actuators have been installed, or, find the alarm brain and get a make and model and get a remote for it, program the remote and erase any other remotes that may be stored in the brain, if you don't have the remotes, [most come with two] for the alarm, sombody else may.94
Old 04-09-2012, 07:38 PM   #10
composurey
composurey's Avatar
soo lube the cords?
Current teggy build
http://honda-tech.com/showthread.php?t=3046014
Originally Posted by low91rex View Post
Vtec heads? Is is a v8?
composurey is offline   Reply With Quote
Old 04-09-2012, 10:52 PM   #11
raverx3m
raverx3m's Avatar
theres no cords they re rods.
Old 01-10-2013, 12:53 AM   #12
wuteng
my actuators are dead on my integra. what is the better route, aftermarket actuators or factory actuators......
wuteng is offline   Reply With Quote
Old 01-10-2013, 06:16 AM   #13
fcm
Old Fart
fcm's Avatar
OEM are better, aftermarket are cheaper. 94
Old 01-10-2013, 09:05 PM   #14
wuteng
how difficult is it to replace the actuators. take out old ones and put in new ones.....
Old 01-11-2013, 06:41 AM   #15
fcm
Old Fart
fcm's Avatar
Kind of depends on your skill level, the tools you have and if they are OEM or aftermarket.
I can only tell you it is easy for me. 94
Old 01-11-2013, 07:16 AM   #16
Seankuhh1023
Seankuhh1023's Avatar
iTrader Rating: (1)
Shaolin dM
When my door is open and I start the car my locking tab moves back and forth rapidly sounding like a machine gun lol. Lubed up everything. Probably just in need of a new actuator. I have aftermarket ones but not sure if they'll do the job perfectly. I remember fcm telling me aftermarket ones don't have a certain something that oem ones have....?
Originally Posted by sii. View Post
front rim is OEM 3 lug?
Seankuhh1023 is offline   Reply With Quote
Old 01-23-2013, 03:41 PM   #17
KeithBeatty
Locksmith company could able to help you with all your locks concerns.
Hillsboro Lock Change
KeithBeatty is offline   Reply With Quote
Old 08-21-2013, 03:46 PM   #18
solbrothers
y u rusty doe?
1970 Honda CB450
My Garage
solbrothers's Avatar
iTrader Rating: (1)
solbrothers
Send a message via AIM to solbrothers
I had that. Now my driver lock is siezed completely
Originally Posted by 94EG8 View Post
Some guys get tattoos together, some guys go to the gym together, then there's Ash and Solbrothers: Lifetime alignments together
Originally Posted by Rguy View Post
I actually laughed. Well done sol.
solbrothers is online now   Reply With Quote
2000, actuator, acura, door, hear, integra, issues, lock, lockcan, locking, lockunloc, motor, power, replacement, wont, working
Similar Threads
2007 Civic EX automatic door lock issues EBP_Em1 Honda Civic (2006 - Current) 3 08-16-2014 10:05 AM
96 Civic EX - Power Window, Lock, and Mirror Problems Bxarellano Honda Civic/Del Sol (1992 - 2000) 2 05-20-2014 10:23 AM
Help please door locks Kdeezy95 Honda Civic/Del Sol (1992 - 2000) 5 11-11-2013 12:42 PM
97 Civic - wouldn't lock manually or with power lock and then broke arm off actuator poptheclutch Honda Civic/Del Sol (1992 - 2000) 2 01-10-2013 06:18 AM
Power door locks not working on 97 accord dohctor_B Honda Accord (1990 - 2002) 41 11-14-2012 11:35 AM
