Go Back   Honda-Tech > Honda and Acura Technical Forums > All Motor/ Naturally Aspirated
Old 03-10-2012, 05:47 AM   #1
Jabbito
Default Engine dies after reaching Rev limit!
Hello H-T
need help on something, My Engine shuts off while running after reaching my rev limit ( 7.5k rpm) but seems to be ok after i turned it on.
No cell on ecu, and my ecu was just recently tuned
thanks
Jabbito is offline   Reply With Quote
Old 03-10-2012, 07:47 AM   #2
blkSi
Squirre1M4ster munchyz1605
Send a message via AIM to blkSi
Default Re: Engine dies after reaching Rev limit!
I know I can't help you...
But you MIGHT need to provide more information about your setup before anybody can.
Hope you find the problem!
Originally Posted by Lou845 View Post
its running a stock gsr ecu and vtec is not hitting, the guy has the solenoid wired to the horn ............
(sigh)
blkSi is offline   Reply With Quote
Old 03-10-2012, 09:02 AM   #3
Jabbito
oh sorry about that...
im running on a d16y7 or y8 vtec-e, all stock engine, recently chrome tuned, rev limit was set to 7.5k rpm
Old 03-11-2012, 05:39 PM   #4
vtec8200
vtec8200's Avatar
does it do that since the tune?
vtec8200 is offline   Reply With Quote
Old 03-12-2012, 03:22 AM   #5
crazes
Moderator
crazes's Avatar
look at your distrubutor. it might be going bad. happened to me at the track
crazes is offline   Reply With Quote
Old 03-12-2012, 04:36 PM   #6
type_r_teggy
type_r_teggy's Avatar
my setup did that on crome 2, but i TINK its ignition cut vs fuel cut.
type_r_teggy is offline   Reply With Quote
Old 03-13-2012, 03:39 PM   #7
SiR-iNTEGRa
Not sure if I'm understanding u rite but u said u have the rev limiter at 75rpm and it cuts off after u pass it.......could be that the person who tuned ur ecu left the rev limiter on ur car cuts off as a safety measure so u don't blow ur motor its probably ur ignition cut off just change ur cut off limiter to a higher point
SiR-iNTEGRa is offline   Reply With Quote
car, dies, engine, honda, limit, limiter, max, motor, odyssey, point, reaching, rev, revving, rpm, shuts, stalls, turns
