Go Back   Honda-Tech > Honda and Acura Technical Forums > Forced Induction
Old 02-29-2012, 01:21 PM   #1
Broertje
Broertje's Avatar
Default Edelbrock Performer x VS Victor x
Which one do ya'll recommend? I heard victor is more ofr the mid range, and performer for top end. And not to mention the fact its $100 cheaper.
Which one is preferred and why?
Broertje is offline   Reply With Quote
Old 02-29-2012, 01:29 PM   #2
thegatekeeper14
thegatekeeper14's Avatar
Send a message via AIM to thegatekeeper14
Default Re: Edelbrock Performer x VS Victor x
I run a fully ported and polished victor x from Renown Performance. How ever i would like to see the performer x and what it can do. Heck contact Renown and have them port one for you.
Also your gonna wanna share your set up so we can accurately suggest a quality performing manifold for you.
Turbo 92 GSR
thegatekeeper14 is offline   Reply With Quote
Old 02-29-2012, 02:12 PM   #3
Broertje
Broertje's Avatar
Well I havent put a solid setup together, but its gonna be Boosted, +/- 300 WHP.
Old 02-29-2012, 02:26 PM   #4
lsturbo33
lsturbo33's Avatar
For 300 just use a stock manifold.
lsturbo33 is offline   Reply With Quote
Old 02-29-2012, 02:44 PM   #5
joe b
joe b's Avatar
Anything less than 500whp and its a waste !!! Trust me i know !! Stock will be more than sufficient for up 450 whp .
joe b is offline   Reply With Quote
Old 02-29-2012, 03:05 PM   #6
m3tech95
m3tech95's Avatar
m3tech95@facebook.com
Longer runners=lower rpm power increase
Larger Plenum=higer rpm power increase
If your only revving to stock or 8,200 rpm, go with the Performer X = Power-band 4500-8200
"The Performer X intake manifolds for Acura and Honda's are engineered for street/strip applications where peak torque and horsepower gains are realized between 4500-8200 RPM. The larger-than-stock plenum volume and 9" runner length are tuned for producing peak power at high RPM."
If your going to be revving to 10,000 rpm go with the Victor X = Power-band 7000-10,000
"Optimized for maximum power from 7,000 to 10,000 RPM, the Victor X manifold is designed for turbo and all-motor applications. Engineered for high performance, this manifold has four additional bosses for nitrous or added fuel injectors"
This is regardless of if your turbo or N/A that's what range they were designed for. Hope this clears up some confusion about the difference in these two manifolds.
*New Best Time 11.94 @ 114mph 0.00 Reaction Time 1.7 60ft* 100% bone stock B16a2 Motor + 50 Trim Turbo + 15lbs http://www.youtube.com/watch?v=1CKTuCG7JuQ 7th Gear Racing/Morris Tuned/I drive
m3tech95 is offline   Reply With Quote
Old 02-29-2012, 05:05 PM   #7
DarryCar
I have the JG Eddlebrock intake mani on my turbo application. Does anyone know if this is the Vector X or Performer X?
DarryCar is offline   Reply With Quote
Old 02-29-2012, 05:13 PM   #8
DraginX
It is the victor x.
DraginX is offline   Reply With Quote
Old 02-29-2012, 06:15 PM   #9
Turbo-LS
Turbo-LS's Avatar
iTrader Rating: (4)
Send a message via AIM to Turbo-LS
Op aftermarket manifold will increase over stock, perform will be suitable for stock redline and the power your looking for. Victor is for larger turbo and power goals
www.senditracing.com
ECU Socketing, BBG, Vtec
95 DC2 GSR PTE 6266 827hp PB - 9.74 @ 156.66 mph
Turbo-LS is offline   Reply With Quote
Old 03-01-2012, 02:26 AM   #10
Broertje
Broertje's Avatar
Ok thanks everyone, these manifolds cost like $300-400. How much gain will i get over stock AVG? Are we talking like minimal gains due to 300whp or
Old 03-01-2012, 03:50 AM   #11
LS AzZkIkr
LS AzZkIkr's Avatar
bdmuthafka
Under 500hp = skunk2, AEBS, stock
Over 500hp = victorX, Magnus, golden eagle
Just my $.02
Originally Posted by jz98ctr View Post
TECHNICALLY....you're supposed to put 2 spaces after a period. Only 1 space after a comma. But, this IS HT...so all rules of physics, common sense, and grammar fly right out the window.
LS AzZkIkr is offline   Reply With Quote
Old 03-01-2012, 04:59 AM   #12
Turbo-LS
Turbo-LS's Avatar
iTrader Rating: (4)
300whp is 300whp. if might give you a little more low end and mid range power but stock will work fine for 300
Old 03-01-2012, 05:52 AM   #13
Broertje
Broertje's Avatar
Ok thanks
Old 03-05-2012, 06:09 PM   #14
DarryCar
Originally Posted by DraginX View Post
It is the victor x.
Thanks. All it says on it is JG Edlebrock on it. I have had it for a while and just forgot which one I had. It worked great when I had 384whp and it still flows great now at 515whp. Hoping it will still flow good at 600+. Good mani for the price.
acura, difference, edelbrock, eldibrock, good, hondatech, intake, integra, kit, manifold, performance, performer, porting, renown, turbo, victor
