Old 02-28-2012, 08:22 PM   #1
BSG
Icon2 94 Civic LX won't start when ever it rains - no spark
Is there a way to test my ECU?
My car won't start when ever it rains. From what I hear that's either your distributer cap or the ECU.
I already replaced the distributer cap.
Where is the best place to buy an affordable ECU? Can I get one that's rebuilt or from a scrap yard?
Also, how in the heck is moisture getting into the ECU in the first place, when it is inside the car, and inside a sealed box?
The only thing that has me questioning if it is the ECU or not, is that the check engine light comes on and then goes back off.
It cranks like it really wants to start.
BSG is offline   Reply With Quote
Old 02-28-2012, 11:35 PM   #2
bukolkol
Default Re: ECU questions
you should check the basic for distributor check for spark. for ecu check for injector pulse with noid light. check for fuel and pull the code out and need more info like model year of the car.
bukolkol is offline   Reply With Quote
Old 02-29-2012, 04:22 AM   #3
BSG
Sorry, its a 1994 honda civic lx. 4 door.
Old 02-29-2012, 04:53 AM   #4
grumblemarc
The Grumpiest
1996 Honda Civic
grumblemarc's Avatar
iTrader Rating: (4)
Send a message via AIM to grumblemarc Send a message via Yahoo to grumblemarc Send a message via Skype™ to grumblemarc
Have we even bothered to look at the ECU and the area it's installed at to see if there is any moisture getting to it? Or are we just guessing at this point?
FAQs!--How to Turbocharge your Civic--Want a faster Civic?--DIYs
Originally Posted by wantboost View Post
I wish more parents would beat their children, then maybe most of them wouldn't be total spoiled, self absorbed *********.
grumblemarc is offline   Reply With Quote
Old 02-29-2012, 06:02 AM   #5
speedjunkie_g35
2013 Subaru Legacy
My Garage
speedjunkie_g35's Avatar
GANGSTER G35
My guess would be the ecu. If it works when it is dry then I would assume you need to take care of the moisture that is seeping in. It is a common thing in these cars for the passenger floor board to fill up when it rains. You need to figure out where the water is coming in on the firewall and seal it up
-Not sponsored by Mom and Dad Motorsports!!!
Check my build: http://honda-tech.com/showthread.php?t=3031606
Have sold to: Greenitr2009, metalslug, optaire, 96GreenDB
speedjunkie_g35 is offline   Reply With Quote
Old 02-29-2012, 04:10 PM   #6
BSG
There was rust near the ECU but not on it. Just pulled it out, popped it open, and don't see any obvious damage anywhere. No corrosion or black burn mark. Looks perfect.
Crap. Now I really don't know what's wrong with it.
Old 02-29-2012, 05:33 PM   #7
Lil Gnome
Lil Gnome's Avatar
iTrader Rating: (1)
I'm not seeing as to how you got that your ECU is the issue when starting in the rain, unless you know it is getting wet....
From what it sounds like to me is a short, MOST likely for rain water leaking onto a connector, wire, etc.
Make sure the windshield drains are clear as well as the tubes on either side. Inspect area of that would effect starting if faulty or damaged. Grounds, Ignition wiring, fuses.
When you turn you car to the 'ON' position, can you hear the fuel pump, and do all the accessories light up?
What is the extent of your issue? What else does not work? Does it just not crank?
WTB: B16A (S4C/Y21) Transmission, LSV Kit, 96-00 5spd VTEC harness, OBD1 Distributor, FS: http://hondamarketplace.com/showthread.php?t=3131664 R.I.P. John Rodgers aka John Doee -user name: Ya Digg-
Lil Gnome is offline   Reply With Quote
Old 02-29-2012, 10:23 PM   #8
BSG
The ECU was a really good guess, since there was rust next to it and that is the "usual suspect" when a honda doesn't start after the rain.
When the car is turned on everything lights up, you can hear the fuel pump, and it almost almost starts. It cranks. This car wants to start so bad but can't quite make it.
Old 03-01-2012, 01:05 AM   #9
bukolkol
so what have you check so far. so when it rain its does'nt start but when its not raining it start. have you even pull the engine light code yet
Old 03-01-2012, 01:12 AM   #10
d15bvtechatch
d15bvtechatch's Avatar
iTrader Rating: (2)
SingWhenIPoop
Send a message via AIM to d15bvtechatch
Icon4 Re: ECU questions
So it's spark. you hear your fuel pump, your probably getting fuel to your injectors the. your ingnition coil could be going bad.. change your rotor. no need to change wires/plugs since when it does run, all 4 cyl are running? to change rotor, pull distributor cap. 3 phillips screws/8mm. then youll want to pull dizzy off so you can access phillips screw holding rotor and 2 phillips holding ignition coil on. coil is like $60 at autozone.. i had this problem it was ignition coil.
-1998 GPW EK9 -
http://honda-tech.com/showthread.php?t=3015021
d15bvtechatch is offline   Reply With Quote
Old 03-01-2012, 01:22 AM   #11
BSG
Well, I pulled off the distributor cap, which turned out to be fine but replaced that anyway just in case. The rotor was fine and didn't need replacing either. Wouldn't water have had to get through the distributer cap to get into the ignition coil? It was bone dry when I pulled it off, no cracks.
I just went out and tested my fuses, and noticed the "motor check" fuse does not light up. Not even after I switch it out with a fuse that is known to be working.
Old 03-01-2012, 02:25 AM   #12
Lil Gnome
Lil Gnome's Avatar
iTrader Rating: (1)
What's the condition of your exhaust system?
Old 03-01-2012, 04:53 PM   #13
BSG
The exhaust is fine, it doesn't smoke, isn't loud, and I just got my sticker days before so it passed the emissions test.
I'm going to throw a new ignition coil at it and see if that gets it.
Old 03-01-2012, 06:37 PM   #14
Lil Gnome
Lil Gnome's Avatar
iTrader Rating: (1)
Interesting. Keep us posted.
Old 03-04-2012, 11:21 PM   #15
BSG
Believe me, when I figure out what it is I'll be sure to let you all know.
Talked to a mechanic and he said he doesn't think it's the ignition coil, since the distributer cap and rotor are just fine. Said ignition coils in hondas don't go bad, not until well after the 100k mile mark.
It's probably an electrical short somewhere. A friend has suggested I spray the car down with water and try to follow the leak. See where the water is going.
Here's a question: If I check the engine code would that tell me where there is an electrical short? Or would it only tell me about the engine?
Old 03-05-2012, 03:03 AM   #16
Lil Gnome
Lil Gnome's Avatar
iTrader Rating: (1)
You mentioned you found rust near the ECU. So the is rust, (water/moisture) damage in the car?
Did you find any moisture near, or around the ECU when you inspected it?
Old 03-05-2012, 04:11 AM   #17
BSG
No. There was no moisture there. The rust was on the piece of metal its mounted on, it just looked old. There was no rust, corrosion, or moisture on or inside the ecu box itself. Almost wish there was, the mystery would be s4olved.
Old 03-05-2012, 04:49 AM   #18
RonJ@HT
Raising the bar
2000 Honda Civic
My Garage
RonJ@HT's Avatar
Old plug wires can cause the problem you're having.
And what exact fuse are you talking about?
Don't guess, troubleshoot.
RonJ@HT is online now   Reply With Quote
Old 03-08-2012, 05:29 PM   #19
BSG
Do you guys think this could be my main relay going out on me again? I fixed it not too long ago bc the car wouldn't start when it was hot. Is it also rain/humidity-sensitive? But I guess not if I can hear the fuel pump, so idk.
RonJ@HT: Old plug wires can cause the problem you're having.
The plug wires didn't look corroded when I switched out my distributor cap.
RonJ@HT: And what exact fuse are you talking about?
The motor check fuse, in the ABS fuse box under the hood. It's fuse #2
Also while I was inside the car looking at the interior fuse box, I noticed many of my fuses didn't light up even though I know them to be working well, such as the power windows, lights, etc.
Old 03-08-2012, 06:35 PM   #20
94EG8
Honda-Tech gave me this lousy title
94EG8's Avatar
Fuses don't light up...
"Bacon tendercrisp chicken, the most powerful sandwich in its class."
Per ardua ad astra
My F/S thread -> http://hondamarketplace.com/showthread.php?t=2900962
Originally Posted by Knightsport View Post
Hello,
This is Knightsport, from the internet. I will be out of the internet from June 2 and returning on June 11th. In my absence I suggest you pray as there can be only one Knightsport from the internet.
Thank you and God Bless,
-Knightsport
94EG8 is offline   Reply With Quote
Old 03-08-2012, 06:37 PM   #21
Lil Gnome
Lil Gnome's Avatar
iTrader Rating: (1)
Yea dude, check that main relay. I heard the main relay was an issue with 93-97 accords, and like models when it came to temperature. But you seems to have had the same issue, and fixed it as you said.
How did you fixed it?
So you have, power, fuel, and the turning over of the motor. I feel like moisture is somehow getting into your combustion chamber. Not enough to hydrolock, but enough to cause your no start. But I'm assuming seeing as most likely areas of concern are not the cause, or direct cause.
Old 03-11-2012, 04:02 PM   #22
BSG
Had another mechanic over to look at the car and he said I have 3 cracked engine seals leaking fluid onto the spark plugs and that's why it won't start. He pulled the spark plug caps off the top of the engine, and when he pulled them out they had oil on them.
Also can someone tell me how much is reasonable to fix?
Old 03-13-2012, 06:47 AM   #23
BSG
The next mechanic to look at it says oil on the spark plugs wouldn't be enough to keep it from starting and that I needed a whole new ignition. I said why not just switch out the coil and he tried to tell me the coil wasn't servicable. I told him it was and he said I was mistaken. We went back and forth until I said I went on honda-tech.com. That's when he backed down and admitted that it was servicable but pretended he didn't know "Its been a while since I've worked on one of these old hondas."
***update. Switched out igniton coil and damn thing still won't start. Mechanic pulls me aside away from his boss and says 90% I need a new distributer and that I can switch it out myself. (Which is a completely different story from the new ignition I was told I needed a minute ago) The part itself will run me @ least $200.
I will keep you updated on how this goes.
Oh, and he said something about the third coil or something being burnt out...anyone know what the hell he was talking about?
94EG8, a fuse tester lights up, when you tap your fuses to see if they are working.
Lil Gnome, I just switched out the main relay two years ago. Do they go out that fast?
Old 03-13-2012, 09:20 AM   #24
Red_Army
Send a message via AIM to Red_Army
idk about your no start but never ever go back to that shop.
93 Sol JDM SIR II b16a NA
95 Sol D16Z6 Turbo project
Red_Army is offline   Reply With Quote
Old 03-13-2012, 09:26 AM   #25
grumblemarc
The Grumpiest
1996 Honda Civic
iTrader Rating: (4)
What color is your spark?
1994, 94, accord, bsg, civic, coil, d15, ecu, honda, hondatech, lx, questions, rain, rains, spark, start
Similar Threads
98 accord won't start and won't come out of park LSteggyguy Honda Accord (1990 - 2002) 4 06-04-2014 05:45 AM
96 civic lx won't start after it rains DelSol-B18 Honda Civic/Del Sol (1992 - 2000) 15 04-07-2014 06:36 AM
91 LX power window question Blue Bomb Honda Accord (1990 - 2002) 1 09-11-2013 08:58 PM
My car won't start after it rains that747guy Honda Civic/Del Sol (1992 - 2000) 16 07-08-2013 03:47 PM
Weird Starter Problem. STORY inside... _dc4_ Acura Integra 21 05-05-2013 05:05 PM
