Go Back   Honda-Tech > Honda and Acura Model-Specific Technical Forums > Honda CRX / EF Civic (1988-1991)
Old 02-25-2012, 11:44 AM   #1
katy purry
Default Easiest way to remove alternator from CRX???
Hey party people, so I just got done unhooking all the wiring & unbolting my alternator (top and bottom bolts) and it is currently free however I ran into a bigger problem, I can't get the damn thing out. I cannot pull the alternator straight out because the master cylinder is in the way and the only obvious route is blocked by the intake manifold. I was wondering if anyone has ever experiences this and if they might have a suggestion, maybe even an obvious suggestion I overlooked? I was also wondering is it possible to drop it out of the bottom? I haven't had an opportunity to get the car up to take a look from underneath but from what I can see, there's not much of a gap between the engine and the axle for me to do it but it looks the most promising. I did however notice I might be able to take the oil filter off and squeeze it through but is that really necessary? This really seems like a major design flaw and a major inconvenience. I've never had this much problem replacing an alternator.
Thoughts?
katy purry is offline   Reply With Quote
Old 02-25-2012, 11:46 AM   #2
KINGVEM^^ED6
1991 Honda Civic
My Garage
KINGVEM^^ED6's Avatar
iTrader Rating: (1)
Default Re: Easiest way to remove alternator from CRX???
Take off the lower bracket jack car up put on jack stands slide under n wiggle it out
Originally Posted by tonylovesjdmEF9 View Post
i would choke my ex it was pretty fun and wild
KINGVEM^^ED6 is offline   Reply With Quote
Old 02-25-2012, 12:03 PM   #3
katy purry
What exactly are you referring to by the lower bracket?
Old 02-25-2012, 12:06 PM   #4
KINGVEM^^ED6
1991 Honda Civic
My Garage
iTrader Rating: (1)
The brackets that hold the alt to the motor
Old 02-25-2012, 12:14 PM   #5
katy purry
Cool. Awesome. From the looks of it it will be a very... very tight squeeze against the axle. And you're pretty positive this will work? I lost my jack stands and I'm not really looking forward to buying anymore unless I absolutely have to today.
Old 02-25-2012, 12:20 PM   #6
KINGVEM^^ED6
1991 Honda Civic
My Garage
iTrader Rating: (1)
You could jack it up and not use jackstands
I always use jackstands when going under a car
Itd be a sad day if u were wiggleing it out jack moves u die
All to save 30 40 bux :/ and plus its a good investment
And yes this is how i do it on my sohc civic
Old 02-25-2012, 12:38 PM   #7
Nooch
1990 Honda Civic
Nooch's Avatar
Yeah, the guy who rolled my brother's fenders got crushed to death while working on his own car. From what I remember his wife finally found him like half an hour later...
So go buy some ****ing jackstands.
Nooch is offline   Reply With Quote
Old 02-25-2012, 01:06 PM   #8
crvtectim
Yep, just the other day driving by an O'Reilly's parts store, saw fire trucks and ambulance in parking lot with workers trying to get a car lifted off a person. Not sure if they survived...
NEVER trust a jack! At least use something ghetto like blocks or wheels lol!
To get my alt, I simple remove my oil filter, pull alt, leave bracket on the block, and slide the alt along the rear crossmember until a space opens up to pull it through.
Edit: B20VTEC in CRX
Originally Posted by delsol92 View Post
i tried to help from my experiences, cus on my crx if i take the distributor off and the fuel rail if i turn the little thing on my distributor my injectors squirt fuel
crvtectim is offline   Reply With Quote
Old 02-25-2012, 01:33 PM   #9
hatch89
hatch89's Avatar
Take your intake tube off
Stand in front of car
Get alt in right hand
Reach around and behind intake mani with left hand
Hand alt from right to left
Remove alt on pass side.
No jack stands required.
GL
hatch89 is offline   Reply With Quote
Old 02-25-2012, 02:09 PM   #10
k20rex
k20rex's Avatar
Send a message via ICQ to k20rex Send a message via AIM to k20rex
both ways work around the intake manifold or from the bottom but if you go out bottom turn the wheel for a little more room with the axle
88 crx si k-squad
k20rex is offline   Reply With Quote
Old 02-25-2012, 03:10 PM   #11
JDpower
I just take of my master cylinder and take it out the top its pretty fast, dont even have to jack the car.
JDpower is offline   Reply With Quote
Old 02-25-2012, 06:30 PM   #12
crvtectim
That requires bleeding the brakes after though. ^
I'm curious how you guys that do not jack the car up get the bottom alt bolt back in and lined up with the notch in the bracket without a major fight?
And to the op, what is the major inconvenience with removing the oil filter? Haha
Old 02-26-2012, 12:32 PM   #13
katy purry
Thanks guys. I just unbolted the bottom bracket that holds on the alternator and it slid right through the gap in the wheel well and it came right out.
Old 02-26-2012, 01:04 PM   #14
KINGVEM^^ED6
1991 Honda Civic
My Garage
iTrader Rating: (1)
Toed u
Old 02-26-2012, 08:39 PM   #15
srok1
2007 Infiniti G35
srok1's Avatar
Send a message via AIM to srok1
Damn, I remember like 7 years ago I had to take the alternator out and we ended up taking it out through top without removing anything. It took us a long *** time but it happened. I wish someone gave us some tips on how to take the damn thing out awhile ago lol.
Whenever I see an adult on a bicycle, I have hope for the human race. ~ H.G. Wells
srok1 is offline   Reply With Quote
Old 02-27-2012, 05:15 AM   #16
gringo7718
1991 Honda CRX
gringo7718's Avatar
I recently removed mine through the top, but the car has a B-series if that makes a difference. (I remove the upper alternator mounting bracket, and I move the fuel rail over an inch or two)
Official EF Civic CRX - Alternator thread - http://honda-tech.com/showthread.php?t=2986970
Selling my 91 CRX B16 - http://hondamarketplace.com/showthread.php?t=3124564
EF CRX/Civic water leak thread
- http://honda-tech.com/showthread.php?t=2832053
gringo7718 is offline   Reply With Quote
Old 02-27-2012, 05:56 AM   #17
crx_si-r
crx_si-r's Avatar
carlos zapien c_zapien
Send a message via AIM to crx_si-r
Ummmm. No.
I unbolted my master cylinder from the booster, moved it aside and alternator came right out. As long as you don't open up the brake lines there is no need to bleed the system.
Crx with Lsv and skunk2 manifold
CJ's Tuck Harnesses
CRX LOG
Instagram c_zapien
crx_si-r is offline   Reply With Quote
Old 02-27-2012, 08:02 AM   #18
Glowicki
1991 Honda CRX
I replaced my alternator in november on my rex, had to pull it out through the wheel well.
Glowicki is offline   Reply With Quote
Old 02-27-2012, 09:43 AM   #19
crvtectim
Originally Posted by crx_si-r View Post
Ummmm. No.
Old 03-07-2013, 06:48 AM   #20
heli_ebook
Icon2 Re: Easiest way to remove alternator from CRX???
Ummmm. No.
I saw a video on Youtube about this, Quality of which was TERRIBLE and you can't see ****.... but which WAY do you shift it? Towards the center or towards the fender? Do you raise it or what? I need to know exactly what is done so my 2nd attempt at this job won't end with me putting the damn thing back again and destroying a 3rd battery.
My next car will be a P.O.S. Bonneville or something, you're NOT saving any money on these stupid cars. Not when you add up parts and maint.
heli_ebook is offline   Reply With Quote
Old 03-07-2013, 07:04 AM   #21
4drEF
4drEF's Avatar
Slide it behind the motor and out the passenger side.
No joke.
Unbolting master cylinder and lifting through top is easier though.
Just take a little care when maneuvering the hard lines.
All of my posts should be considered for being made into a sticky.
4drEF is online now   Reply With Quote
Old 03-08-2013, 07:02 PM   #22
canadaSi
[quote=4drEF;48539326]Slide it behind the motor and out the passenger side.
No joke.
Yes this works, just removed one heater hose and it came out.
canadaSi is offline   Reply With Quote
1988, 1991, 88, alternator, civic, crx, easy, element, honda, pull, removal, remove, taking, youtube, yu
Similar Threads
Low voltage problem possibly ELD problem PR8urVtec Engine Management and Tuning 18 01-15-2014 09:30 AM
First post, a few questions ... need your help please!!! SubwayEatFresh Honda Civic (2001 - 2005) 5 04-29-2013 11:18 AM
b16/crx alternator bracket bolts won't budge thecorey Honda CRX / EF Civic (1988-1991) 5 11-21-2012 06:31 PM
Another Crank Pulley Fell Off HighMileageDude Honda Civic/Del Sol (1992 - 2000) 11 09-11-2012 11:43 AM
**FAQ** How to change your 96-00 D series alternator mkazm83 Honda Civic/Del Sol (1992 - 2000) 24 08-19-2012 04:47 AM
