Old 02-21-2012, 11:16 AM   #1
suje
1996 Honda Civic
Default timing mark for crank pulley?
took out my crank pully without aligning my TDC for the pulley
now how do i find the right timing for the crank pulley?
suje is offline   Reply With Quote
Old 02-21-2012, 11:27 AM   #2
grumblemarc
The Grumpiest
1996 Honda Civic
grumblemarc's Avatar
iTrader Rating: (4)
Send a message via AIM to grumblemarc Send a message via Yahoo to grumblemarc Send a message via Skype™ to grumblemarc
Default Re: timing mark for crank pulley?
That would be a Frequently Asked Question. Did you check the FAQs?
FAQs!--How to Turbocharge your Civic--Want a faster Civic?--DIYs
Originally Posted by wantboost View Post
I wish more parents would beat their children, then maybe most of them wouldn't be total spoiled, self absorbed *********.
grumblemarc is offline   Reply With Quote
Old 02-21-2012, 11:28 AM   #3
Dc4LsTeG
EK9
Dc4LsTeG's Avatar
iTrader Rating: (7)
If you didn't touch the timing belt just put the pulley back on
98 Civic Type R/Boosted B18C5
Dc4LsTeG is offline   Reply With Quote
Old 02-21-2012, 11:37 AM   #4
kyden
Send a message via AIM to kyden
the pulley is keyed. you can't really put it on wrong (other than backwards, which is extremely improbable)
kyden is offline   Reply With Quote
Old 02-21-2012, 12:16 PM   #5
98civdx
Master Detailer
98civdx's Avatar
This.
What are you doing to the car? Timing belt?
RIP Michael Young. 3-26-1991 9-2-2013
98civdx is offline   Reply With Quote
Old 02-22-2012, 10:55 AM   #6
suje
1996 Honda Civic
basically im just replacing the t-belt. im guessing i jus have to put it back on TDC?
t-belt threads were shredded so im guessing timing jumped
Old 02-22-2012, 11:22 AM   #7
98civdx
Master Detailer
98civdx's Avatar
Yes, you will want to set it back to TDC before you finish it up.
Put everything the belt back on, go around water pump, tensoner, but leave it that bolt loose, and off of the cam gear.
Put the lower timing cover back on, and re install all bolts.
Put crank pulley back on. Tighten bolt.
Rotate CC and put the white mark on the pulley in the middle of the < mark on the cover.
The crank is now at TDC.
Set cam to TDC, should be a up mark.
Put belt on cam gear, spin her over a few times, and insure both are at TDC.
Old 02-22-2012, 03:29 PM   #8
suje
1996 Honda Civic
ok im soo lost now. i did everything mentioned on http://www.team-integra.net/forum/bl...nt-g3-teg.html
car still wont start. i've already tried moving the distributor around, didnt work. any suggestions?
Old 02-22-2012, 03:32 PM   #9
98civdx
Master Detailer
98civdx's Avatar
You should have never even touched the distributor.
Is the timing correct? You mention you thought the belt may have jumped? You could have done some internal damage.
Old 02-22-2012, 03:39 PM   #10
suje
1996 Honda Civic
timing and everything is correct. not even off by a teeth.
i've only tried to start it up 3 times after i got the TDC. misfired twice and that was about it. not all the belts are back on there besides the t-belt, unless the alternator places a part in it too
Old 02-22-2012, 03:45 PM   #11
98civdx
Master Detailer
98civdx's Avatar
I would deffinetly put the alternator belt back on!
What else did you touch?
Did the timing belt jump?
Old 02-22-2012, 04:12 PM   #12
suje
1996 Honda Civic
lets just say, before i even touched the cam gears, the TDC marks were almost on opposite sides
must have jumped due to the fact that at least 10+ teeth on the t-belt were shredded
hopefully i can slap everything back on during the weekends
Old 02-22-2012, 04:15 PM   #13
suje
1996 Honda Civic
ohh fyi, all that i have touched is everything that was needed to get to the t-belt
and jus the distributor
Old 02-22-2012, 04:16 PM   #14
98civdx
Master Detailer
98civdx's Avatar
Get a compresson checker, check the engine and come back with the numbers.
Me thinks that engine is ****ed.
Old 02-22-2012, 04:19 PM   #15
suje
1996 Honda Civic
same here, i think the motor is dead. my dad said he plugged cylinder 1 with a napkin and tried starting the car
nothing happened, when the napkin was suppose to pop out
well its probably time to go back to stock
belt, civic, cover, crank, crankshaft, ef, honda, integra, mark, marks, puley, pulley, pully, team, timer, timing
