Go Back   Honda-Tech > Honda and Acura Technical Forums > Forced Induction
Old 02-20-2012, 05:51 PM   #1
BoostedEK964D
Icon2 Chipped Compressor Wheel, Big Deal?
Just picked up this Turbonetics T3/TO4E 57 trim .63 a/r exhaust up for 150 bucks online. Spins freely and was used last winter. Only issue is 1 blade is bend slightly and one is chipped . Do you guys think it needs new wheel and balancing or can I get away with one season on it like it is? I realize that one gram can throw it off balance and destroy motor /turbo.Just wondering what you guys think. How much is it usually for someone to rebuild this? Pics below , Thanks for your time guys
BoostedEK964D is offline   Reply With Quote
Old 02-20-2012, 05:57 PM   #2
DirtyDA9
DirtyDA9's Avatar
Default Re: Chipped Compressor Wheel, Big Deal?
Yes, they need to be precisely balanced, and that will definately throw it off.
Sie können keine Zauber Honda ohne DA
My other car is a DSM (478hp ran 11's)
DirtyDA9 is offline   Reply With Quote
Old 02-20-2012, 06:03 PM   #3
LocoJoe
LocoJoe's Avatar
Send a message via MSN to LocoJoe
1 is chipped but all the blades have leading edge damage. That wheel does not work.
LocoJoe is offline   Reply With Quote
Old 02-20-2012, 06:06 PM   #4
BoostedEK964D
Thanks guys , how much does rebuild usually run?
Old 02-20-2012, 06:09 PM   #5
eg6-jarhead
eg6-jarhead's Avatar
iTrader Rating: (1)
just get a new wheel. unless u want to rebuild the whole thing.
new wheel, balanced. done.
MY BUILD THREAD
MY YOUTUBE
CX HATCH H22 18PSI = 10.81 @ 137MPH.
eg6-jarhead is offline   Reply With Quote
Old 02-20-2012, 06:10 PM   #6
eg6-jarhead
iTrader Rating: (1)
and be careful those shaft threads are usually reverse threaded!
MY BUILD THREAD
MY YOUTUBE
Old 02-20-2012, 06:14 PM   #7
BoostedEK964D
Thanks eg6 , I plan on new wheel and balance. Where can I find the exact wheel I need ? Should I call Turbonectics ? Someone said these r same as a garret model.
Old 02-20-2012, 07:01 PM   #8
93lsv_turbo
hold on i know common sense might tell you scrape it but i fixed many worse blades on turbine engine. the question is can you fix it and drive with it YES you can. your going to lose performance no doubt. if you plan on buying a new wheel try clipping and blending that one, run it and if it doesnt work you got a new one anyways. if you want to give it a try ill give info on how to clip and blend.
93lsv_turbo is offline   Reply With Quote
Old 02-20-2012, 07:13 PM   #9
CrackingVTEC
CrackingVTEC's Avatar
iTrader Rating: (2)
INFECTED R3CTOM
Damn that looks like crap.
CrackingVTEC is offline   Reply With Quote
Old 02-20-2012, 07:32 PM   #10
BoostedEK964D
yea im interested 93 slv.
Is this from balancing? I hope so . Back side of comp wheel , just removed it sence it needs new one anyway.
Old 02-20-2012, 07:32 PM   #11
93lsv_turbo
he already knows its damaged. im not telling him its not and im not telling him that this will fix it. im telling him he can make it work (cant tell him how the turbo will flow) until hes ready to buy a new one.
Old 02-20-2012, 07:37 PM   #12
BoostedEK964D
Few More pics for u guys
Before paint
After Thermal Paint
Old 02-20-2012, 07:38 PM   #13
BoostedEK964D
This turbo is for project motor for my swap. Not on a car , got a Big 16g on my daily now guys
Old 02-20-2012, 07:51 PM   #14
93lsv_turbo
this is all TURBINE theory. ive never dont this to a turbo. gona hook you up with pics so give me a sec
Old 02-20-2012, 08:28 PM   #15
93lsv_turbo
tools:
tin snips, neutral (no left or right hand you dont want an angle on it)
metal sanding file, coarse and fine.
ruler, if you can find a lil metal 6 inch ruler that would be great but you need some kinda ruler
step 1: you want to cut as much of the damage area as possible WITHOUT taking to much out. like this
step 2: measure out from the center (along the top of the leading edge) to where you cut. then measure from the root (where the blade meets the wheel or bottom) to where you cut.
step 3: repeat the steps backward (measure then cut) to the blade 180 deg (the one right across from the damaged one).
step 4: you want to file (start coarse the then fine) the cut you just made down so that there is no high metal and so that the pitch of the blade matches the others as best possible.
as for the blades with the leading edge damage follow step 4
Old 02-20-2012, 08:39 PM   #16
sdubfid
sdubfid's Avatar
If you don't want to replace the wheel you can build the chips up with weld and reprofile it and balance. I've done it many times for rebuilds at work for oddball turbos with no readily available wheels.
sdubfid is offline   Reply With Quote
Old 02-20-2012, 09:38 PM   #17
BoostedEK964D
Thanks man but sense its already sitting here and not on my car n needed im rebuild it seals and bearings and have it balanced . Are there upgraded wheels available or just garret one?
Old 02-20-2012, 09:53 PM   #18
TheShodan
TheShodan's Avatar
iTrader Rating: (6)
Send a message via AIM to TheShodan Send a message via Yahoo to TheShodan
Just the Garrett ones. You've been PM'd..
“Don't let the opinions of the average man sway you. Dream, and he thinks you're crazy. Succeed, and he thinks you're lucky. Acquire wealth, and he thinks you're greedy. Pay no attention. He simply doesn't understand.” -Robert G. Allen
TheShodan is offline   Reply With Quote
Old 02-20-2012, 10:41 PM   #19
BoostedEK964D
kk got u back lemme get ur wheel
Old 02-24-2012, 05:50 PM   #20
B and B
1992 Si Hatch _
B and B's Avatar
iTrader Rating: (3)
Can't see op's pics...wanted to see how bad this is.
92 Civic Si LsV Holset T1 tuned
Originally Posted by turbohatch96y7 View Post
This is FI we do whatever we are told
B and B is offline   Reply With Quote
Old 02-24-2012, 07:41 PM   #21
DirtyDA9
DirtyDA9's Avatar
Wow, I am never buying a turbo off of 93lsv turbo or sdubfid... Christ.
Old 02-24-2012, 08:16 PM   #22
crvtectim
All I could here was dude saying in a last zohan voice, "I make the blades silky smooth." Snip snip
Originally Posted by delsol92 View Post
i tried to help from my experiences, cus on my crx if i take the distributor off and the fuel rail if i turn the little thing on my distributor my injectors squirt fuel
crvtectim is offline   Reply With Quote
Old 02-24-2012, 09:05 PM   #23
93lsv_turbo
hahaha yea man ive done it quite a few time to turbine engine. of course there are alot of differences but the main theory is the same as far as the compressor.
here is a t701c i just finished clipping and blending. 5 axial 1 centerfugal compressor rotors
DirtyDA9
i wouldnt do this to my turbo. it would KILL the performance of the compressor. the question was could he make it work and the answer is yes.
balanced, blade, bumps, chip, chipped, compressor, honda, hondatech, painted, s2000, sand, small, tech, turbine, turbo, turbonetics, wheel, wheels
