> Honda Accord (1990 - 2002)
Old 02-19-2012, 09:44 PM   #1
kitt
Default CEL P0401 - Insufficient EGR Flow
Hi guys. My 1999 Honda Accord set the CEL P0401 code (insufficient EGR flow). I reset the CEL and it came back a few weeks later (I think it was a warmer day than the previous days). Anyways, I'm getting about 21 MPG city (I know clogged EGRs can reduce fuel efficiency), is that particularly low?
I've seen some tutorials/videos (none specific to my model). I haven't seen anything that was that good explaining the process. Also I've seen people clean out their whole throttle body / intake manifold which looks pretty complicated.
It doesn't look like I can reach 1 of the 2 bolts (the one closer to the manifold) without removing other parts out first. Should I just take it to the shop?
kitt is offline   Reply With Quote
Old 02-22-2012, 06:20 PM   #2
ricebike
ricebike's Avatar
Default Re: CEL P0401 - Insufficient EGR Flow
http://www.hondaaccordforum.com/foru...-accord-31002/
and
http://honda-tech.com/showthread.php?t=2691467
and
http://www.driveaccord.net/forums/sh...ad.php?t=31865
and
http://honda-tech.com/forumdisplay.php?f=2
cleaning the throttle body valve is much easier than this in comparison
Wife's'95 Accord LX 4dr F22b2 she gave this away to a friend since it's still mechanically sound; now has a 2005 MDX... worse mpg & takes premium to boot (she's ignoring the last part & using regular octane)
ricebike is offline   Reply With Quote
Old 02-22-2012, 10:45 PM   #3
h0p3l355dork
Cleaning helps but in the end, I had to replace the EGR altogether to make my P0401 go away on my 99 accord :/ There's a cleaning procedure that requires taking off the entire intake manifold. Check that one out.
h0p3l355dork is offline   Reply With Quote
Old 02-23-2012, 05:33 AM   #4
ricebike
ricebike's Avatar
already stated in one of the 4 links i posted
be sure to rule out the passageways and vacuum hoses first before replacing the valve
try blasting the valve itself with some carb cleaner as well
Old 02-23-2012, 03:58 PM   #5
lowcd5
1996 Honda Accord
i had the same problem on my 96 i replaced the egr and that wasnt the problem so talked to a guy that helps work on my cars and we found out that the egr ports on the intake under the fuel rail were full of carbon
lowcd5 is offline   Reply With Quote
2000, 2002, 2004, 99, accord, code, egr, flow, homda, honda, insufficient, lx, p0401, po401, valve
