> Honda Accord (1990 - 2002)
Old 02-13-2012, 09:49 PM   #1
05foresterxt
iTrader Rating: (1)
Default 2000 Accord auto transmission CEL codes
Hello,
A friend of mine has had her 00 Accord auto for about 30k+ miles. The car is almot hitting the 200k miles. She recently got the below CEL codes regarding the auto tranny.
What would be the best route to fix her problem? Is it worth it to even fix it? Thanks.
41-01 incorrect gear ratio
46-01 clutch pressure malfunction
05foresterxt is offline   Reply With Quote
Old 02-14-2012, 01:06 AM   #2
MAD_MIKE
MAD_MIKE's Avatar
Default Re: 2000 Accord auto transmission CEL codes
IIRC on the end cover of the transmission there is an elctrical switch mounted. This indicates to the PCM what gear has been selected. If it is out of adjustment or has been damaged it could be sending conflicting inputs to the PCM.
-Michael ....................................How to remove/install AT in '94-'97 F22 Accord Troubleshooting
Do you know, TheMuffinMan?...........CRIPPLE FIGHT!!!!!!! - phootbag
MAD_MIKE is offline   Reply With Quote
Old 02-14-2012, 01:22 PM   #3
05foresterxt
iTrader Rating: (1)
Has anyone else had this issue? How do u troubleshoot/adjust this switch?
2000, 2002, 4101, 4601, accord, auto, cel, civic, code, codes, crv, honda, read, trans, transmision, transmission
