Door lock problems
Old 02-10-2012, 01:55 PM
mnelson696's Avatar
Default Door lock problems
Hi i just bought a 99 Honda Accord Ex. When i bought it everything was in great shape with the exception of the door locks. For one it had no FOB, but im going to buy one off ebay and program it myself for like 40 bux. But when you press the power lock switch some of the locks dont go up and down. You can hear em like click and stuff though. Been trying to do a little research on it, and it sounds like door lock actuators? My question is do i need to replace all four actuators? any insight would be appreciated.
Old 02-12-2012, 08:20 AM
75aces's Avatar
Default Re: Door lock problems
The buzzing and clicking are signs of the lock acctuator going out. The item you are looking for is item 6 and 28. 6 is the acctuator and 28 is the assembly.
http://www.providencehondaservice.com/order-parts.aspx
Follow this link to purchase the parts. Good luck.
Old 02-12-2012, 11:49 AM
CD5_67717's Avatar
mines doing the same thing
Old 02-12-2012, 10:54 PM
brianb242's Avatar
i can trouble shoot this with you, but I need you to run a few tests, 1 doors do not lock or unlock with driver door switch? 2, doors do not lock or unlock with passenger door switch? 3, doors not lock or unlock with key in driver or passenger door outer lock cylinders? run these few quick tests get back to us. it will pin point your problem. if you want to just pm me.
Old 02-12-2012, 10:57 PM
brianb242's Avatar
90% of the time its the actuators, just do the above and I can tell you which one is giving you problems
Old 02-13-2012, 01:13 PM
chikin pickle's Avatar
Do your locks make a buzzing sound? the broken ones?
If so take apart the lock actuators themselves and look inside for a small spring. It should have busted loose from it's plastic retaining slot. Get a shim (Small machine screws work great) and shim that spring back under compression in it's hole. Will fix the issue.
Old 02-14-2012, 05:04 AM
oc9979's Avatar
I am going to try that because my rear actuators are not working
MIBPreacher
Honda Civic (2001 - 2005)
02-03-2013 04:38 PM
William1991b
06-26-2011 04:00 PM
mutiny93
06-26-2011 11:43 AM
aquito
07-15-2009 02:36 PM
stevek89
04-25-2006 04:44 PM
Quick Reply: Door lock problems
